sludge on oil filler cap
agrim Dec 28, 2010
  1. agrim
    agrim New Member
    Can someone tell me if this is a major problem,
    Oil light came up on dash, went to top oil up when I discovered when I removed the cap it was coated in a brown sludge.
    Can anyone explain this, if a major can get dealer to fix as still in warranty
  2. A3-ALF
    A3-ALF Member
    40
    At this time of year it's not unusual to see a bit of mayo/sludge under the filler cap if the car is only doing short runs and with the cold temperatures then you will see a bit of condensation inside most engines. Which doesn't mean there is anything sinister going on a good run and getting the engine nice and hot will get rid of any condensation. But the fact your oil warnining light has come on tends to point towards maybe using a bit more oil than is normal so if the car is under warranty get the dealer to look at it asap.
    HTH
    Alan
  3. agrim
    agrim New Member
    Thanks for that, I do only 10 miles a day to work so not really working the engine, although I will get it checked out in the new year.
    thanks once again
  4. brough74
    brough74 Member
    423
    22
    i would keep an eye on it, could be the head gasket going ?
  5. Jonay
    Jonay Member
    274
    What model and age of car?
  6. NHN
    29,551
    1,777
    Yes always quote car model, year & engine type as helps us advise what we know of.
  7. paddy
    paddy Audi=No fault code, no idea Team Ibis Audi S3 Black Edition DSG
    5,363
    203
    As an aside i have never had to top up the oil in 50k miles so as Nige says, model age mileage etc is a must for anyone to give meaningful advice.
    If you have any doubts inform the dealer because if a related problem crops up out of warranty you can point out that they were made aware of a potential problem while still covered.
  8. NATE6874
    NATE6874 Member
    35
    Hi, I have the same problem with mine, little bit of "mayonaise" as someone called it. Only in the winter though. summer is fine... I just wipe it off and any other residue that I can see.
