Slow wipers
Discussion in 'A4/S4 forum(B5 Chassis)' started by Rsl78, Feb 27, 2013.
  1. Rsl78
    Rsl78 New Member
    Feb 14, 2013
    Hi there hope someone can help me, bought my tqs a couple of weeks ago, but the one thing that is bugging me is the wipers seem to be very slow, even on fast setting are painfully lethargic is it a common fault?
  2. Advert Guest Advertisement
  3. Ian2012
    Ian2012 Active Member
    Oct 28, 2012
    473
    29
    It's quite common there is a how to on the site, they basically need stripping and regreasing, i have done both of our cars with the motor in situ but it's easier if you pop it on a bench, just don't lose the circlips on the spindles, oh and the arms are more than likely on very tight, i needed a small puller to remove mine, i have now bought a wiper puller.
  4. tonya4
    tonya4 TDi Powerrrr
    Aug 9, 2010
    408
    Mine were like this,I sprayed wd40 on the spindles and after a few tries they are now fine
    tony
  5. Ian2012
    Oct 28, 2012
    473
    29
    The problem with just wd'ing is that it washes out quite quickly.
  6. tonya4
    tonya4 TDi Powerrrr
    Aug 9, 2010
    408
    I wd it about every 6 weeks now,it's been fine for over a year now.Maybe the problem is caused when they're not used for a while?
    tony
  7. Mackers
    Mackers Member
    Sep 15, 2011
    291
    I spray lithium grease every so often on the ball joints and spindles.
  8. Rsl78
    Rsl78 New Member
    Feb 14, 2013
    Gonna try wding at the weekend, they just don't seem to change speed.
  9. nemo2182
    nemo2182 Member
    Oct 2, 2005
    130
    WD is a temp fix or not even a fix at all (didnt work for me) Strip them and do it properly. The fault is caused by the metals on the spindels and arm pivots fusing together. There are many simple how to's knocking around, and I have to say I was amazed at the difference, they asolutely fly now!!! But take your time, get a hold of a dimel, some WD, some good old grease. The problem with WD is it will take moisture out the pivot, but will not lubricate it for the future.
