slight whistling noise
B5NUT Apr 15, 2010
  1. B5NUT
    B5NUT Well-Known Member VCDS Map User quattro Audi A6 Audi Avant Owner Group S-line owners group
    3,644
    624
    I think one of the one of the pipes for the turbo is split causing a slight whistling noise, which you can only hear when the window is down. anyone know if one pipes is more prone to splitting than others?
  2. Blue_Thunder
    Blue_Thunder Well-Known Member
    1,767
    31
    What engine do you have?
  3. Nez
    Nez Member
    598
    It could be the clip lose.
  4. Broken Byzan
    13,235
    464
    Mine does it, its the turbo spooling on mine as i have an airtight system.
    I like to feather the throttle and try to play tunes on it sometimes... Sad yes, fun.. Meh !!
  5. B5NUT
    3,644
    624
    It's the 1.8T, could be a hose clip so will check them, but I think it's a split hose.
  6. aragorn
    17,894
    689
    are you down on power?
    If you were dumping boost thru a split hose or a loose clip it wouldnt run very well i'd expect...
  7. B5NUT
    3,644
    624
    It does feal a little down on power but not by much. The car is runnig fine, and there are no fault codes on the engine!
  8. Broken Byzan
    13,235
    464
    is it w whistle or an occasional fluttering type sound?
