Slight ticking from engine S4 B5
adidasandy Mar 26, 2012
  1. adidasandy
    adidasandy Member
    271
    It sounds like the exhaust have a slight leak but I don't think it's that. Seems to be coming from the drivers side middle of the cam. The fuel pressure regulator is ticking away s oI woder if it is that but it's hard to listen for anything else when all I can hear is the FPR. Are they generally noisey or just when they're failing?
    Andy
  2. aragorn
    18,019
    714
    Injectors generally tick, but you only typically notice them when your listening closely at the engine.
  3. murran
    murran Well-Known Member
    1,545
    39
    solenoid for the charcoal filter on the fuel tank breather system? these tick when in normal operation.
  4. Jason.s
    Jason.s Active Member
    2,879
    348
    Especially if the plastic on said valve cracks or snaps off.
  5. AudiiduA
    AudiiduA Member
    359
    Fuel pressure reg!!
