Slight problem
S4_SAT Aug 28, 2007
  1. S4_SAT
    S4_SAT Stuck in 3rd
    74
    I can't seem to get any power above 4.5k when driving on the motorway. Usually I can get to 70mph with no probs in 4th gear,now it struggles in 5th. Any ideas? The car is a 98' 1.8 20v non turbo.
  2. Markey
    Markey Active Member
    2,175
    sounds like there could be a boost leak, or the car could be in limp mode, have you done anything or had anything changed N75J etc?
  3. S4_SAT
    S4_SAT Stuck in 3rd
    74
    Boost leak? It's non turbo. Unplgged the MAF sensor then started the car and seemed to run fine. Plugged it back in and went for a run and was ok. Will check into it again after e38.
  4. fermented
    fermented New Member
    19
    I wouldn't have thought an n/a 1.8 would have much in 5th at 70mph anyway :p.
    exhaust sound normal?
  5. S4_SAT
    S4_SAT Stuck in 3rd
    74
    Oi :asskicking: It's usually ok until 3 figures but it didn't have much for some reason. The cat is going so was wondering if that would have anything to do with it. The flexijoint on the downpipe is blowing. :confused:
