slight problem with my new 1.8t a4
p771 apm Jun 11, 2010
  1. p771 apm
    p771 apm New Member
    i was using the car the other day and i was on the motor way doing about 80 when the car lost all power and died
    my father in law took the car to his garage and we had a look
    seemed to be down on compresion !!
    cyl 1- 0
    cyl 2,3,4 -150
    turns out to be the con rod it has snapped and span round and smashed through the sump
    so now i need a new engine
    dose any 1 no of any were near bristol i can get 1 asap
  2. phoenixv6quattro
    phoenixv6quattro staylowmovefast
    1,396
    Check ebay and piton heads. There is always usually a few floating about. Are you running standard boost? The reason I ask is thats not very common a thing to happen!
  3. very very uncommon for these to snap rods unless excessive revs are applied for long periods........ harmonic resonance is a killer
    strange!
    motors go for £150-£500, you get what you pay for IMO
  4. aragorn
    17,876
    687
  5. p771 apm
    p771 apm New Member
    as far as i no the cars all standard
    iv been told the oil pump might have packed up
    iv found an engine for £200 just got to pick it up next weekend
    fingers crossed its a good 1
  6. phoenixv6quattro
    1,396
    Good Luck mate! Remember to replace all the essential running gear too (timing belt/oil pump etc before it goes in) prob save you a fortune in the long run.
  7. Broken Byzan
    13,235
    464
    at the minimum take the sump off and clean the pick up out of sludge/coke etc.
  8. phoenixv6quattro
    1,396
    To add to your kill list MARK................anything trying to advertise on the B5 forum.
  9. Broken Byzan
    13,235
    464
    Rules is rules dude !
  10. p771 apm
    p771 apm New Member
    more bad news guys i brought the engine yesturday got it fitted and the new engine is fubared
    bottom end is knocking it t!ts off
    iv spoke to the company i got it from and they said they havent got another engine so im back to square 1 at the moment
  11. voteforpedro
    voteforpedro Member
    632
    Where are you? I'm thinking of breaking my '96. It's an AEB with 135k ish on the clock.
