Slight Knocking
russ3376 Dec 2, 2013
  1. russ3376
    russ3376 New Member
    21
    Hello everyone!
    Got a 2005 A3 2.0 TDI SLine Quattro..I have a slight knock on the front wheels at low speed when turning left or right. Almost like a stick (which there isn't!) is running round the back of the wheel spoke! Only a couple of seconds but it's there!
    I know for sure one bearing has been replaced not sure about the other.
    Never had Audi before so I'm a bit dumb!
    Thanks!
  2. leeds2592
    leeds2592 When I grow up, I want a 964!
    1,399
    222
    Mine sounded like this, put up with it for a while and then it starting making the noise all the time when driving. Turned out it was one of the wheel bearings.
    Jack the car up and give both front wheels a wiggle, if one of them moves and all the wheel bolts are tight, its probably the bearing on that side.
  3. russ3376
    russ3376 New Member
    21
    Thanks! I'll check it out right now!
  4. davc
    davc Well-Known Member Team Glacier Audi S3 quattro saloon s tronic S3 Saloon
    674
    683
    93
    Sounds like it could be your steering Rack or a loose sub-frame or even a worn ball joint?
  5. russ3376
    russ3376 New Member
    21
    Bearings seem ok... Tight no movement
  6. russ3376
    russ3376 New Member
    21
    Could be yet another visit to the garage..😞
  7. john71482
    john71482 Active Member
    136
    86
    Having the same problem on my 2.0 tdi had the knocking about a month! mine also knocks when accelerating from a stop if i give it a bit more of a push it'll knock as I pull off! And no one can seem to figure out what it is!
  8. wuta3
    wuta3 Well-Known Member
    1,131
    347
    I had a knock in the steering when going past center lock in either direction, has the wishbone/console bushes replaced and that sorted it out.
  9. OVRA3
    OVRA3 Well-Known Member
    1,079
    80
    I also have a knock :-( if I feather the gears it's fine doesn't happen over bumps but if I go for the beans and change hard it knocks and sometimes in first but only everynow and then
  10. Mindak
    Mindak Active Member
    805
    130
    43
    Iv got a knocking from the rear passenger side, sounds like a shock or something :-( under warranty anyway so gunna get it looked at tomorrow!
