Slight jerky acceleration
Japper Jul 30, 2010
  1. Japper
    Japper Ibis S3 Fan Club
    1,495
    2010 S3 with 7k miles and GIAC remap since 1k. Not all the time but sometimes under load and flooring it, it accelerates fine but you can feel a slight 'hiccup' or similar feeling through pedal and car.
    Is this a recirc valve issue, fueling, or coil pack?. Car runs / idles fine.
    Any ideas?
  2. KRL
    KRL Member
    521
    Thats how mine started and it gradually got worse. It ended up being Coil Packs 2 and 3.
  3. Japper
    1,495
    Thanks Karl that's what i thought it was most likely. Is this likely accelerated by the map or are the coilpacks still a weak part, as i new they were on the 1.8T motor.
    Not tried it with map switched off yet to check if it will repeat the problem for Audi tech.
  4. KRL
    KRL Member
    521
    The map will highlight the issue more but I do not think it would necessarily be accelerated. Unfortunately the coil packs on the VAG platform are just another weak point.
    Be glad you have not got a Veyron as you would have 16 coil packs to worry about!!!
  5. chrissy1502002
    chrissy1502002 Member
    238
    Mine also did this, and I replaced all of my coils and now the problem has gone :)
  6. KRL
    KRL Member
    521
    Good news mate I am glad you sorted it.
  7. chrissy1502002
    238
    Cheers, you have no idea how much happier i am with the car now lol
  8. Japper
    1,495
    Help!
    Didn't use car for past few days as had a hire car over weekend to transport family. However this morning the misfire was far worse on driving to work. Called AUDI and they can't get it in this week so advised to call AUDI assist who would sort it at work. Now here's my question, i'm at work and do not have my GIAC switcyh at hand. Do i need to switch it to stock, will he notice? or do i wait till after lunch when i can get home and switch it back?
