Slight Clutch Judder
gazcallyt
Staffs
Guys,
Anybody experienced this before when coming off the clutch I can feel a slight judder via the pedal, also sometimes when changing gear, there seems to be a slight thud when engaging the next gear ?
Gary
Clutch judder when pulling away is often related to a warped flywheel, plate, housing, seizing thrust bearing, or oil is getting on the clutch plate through a weeping oil seal, the oil generally means some slippage if excessive. If it is any of those you are pretty well looking at a complete new assembly at some point in the future. As for the thud, not sure dodgy gear changing too fast :p
895
470
10
