Slight boost problem after fitting Badger5 kit
Benjiman46 Jun 8, 2012
  1. Benjiman46
    Benjiman46 R-Tech Terrorist
    551
    24
    Ok, first of all, I am in NO way saying that the B5 kit causes problems, this is just a problem I've had since I fitted mine and only just got round to writing it up.
    The problem I have is only small, but really annoying and only happens every so often.
    My car has a boost gauge, and it has not been mapped yet and the only mods I have are the B5 V2 TIP, jetex filter and heatshield, Forge008 DV with yellow spring.
    So, with the car fully up to temperature, I'll set off on a closed road/private race track, and nail it through first and second, the car over-boosting to about 12psi and dropping down and settling at around 9psi and all is well.
    Go up into third, and again it will overboost to around 11psi then very occasionally, the engine will make a hissing sound, which sounds as though it's coming from the air intake area and the boost will drop down to 5psi and stay there until I let off, and put the power back on.
    The same applies for 4th, but in 5th and 6th everything is more settled.
    What's happening? Any ideas?
    Also, this maybe totally unrelated, but it's done it since I put the forge DV on; when I REALLY rev the car, I mean round to 7000 RPM, and change gear, I get like a warbling sound (not the same noise as compressor stall) coming from the turbo area... Does anyone know what this noise is and is it bad?
    Sorry for the essay!!
    Ben
  2. Paradox1
    Paradox1 Well-Known Member
    1,833
    88
    Could be a boost leak,sounds simple but have you check ll hoses
  3. Prawn
    11,667
    3,666
    Something else is wrong there Ben, because you're not boosting high enough for a stock S3 anyway!
    I'm sure a stock S3 boosts at around 1-1.1 bar or so? so more like 15-16psi!
  4. Benjiman46
    551
    24
    It's not a boost leak I don't think, as most of the time it holds boost, and I'm pretty sure 9 - 12 ish is right for a standard 210 S3... I'll do yet another standard S3 boost pressure post... :p lol
  5. Benjiman46
    551
    24
    After doing a little reading up, could it possibly be the N75 valve going boobs skyward?
  6. Paradox1
    1,833
    88
    Could be n75 but from my experience its more intermittent. It also doesn't explain why its happend straight after fitting the B5 tip
  7. superkarl
    superkarl MAN OF STEEL
    9,610
    2,481
    get it scanned, no point speculating yet if theres an error telling you exactly whats going on.
    does sound like a leak though
  8. beachbuggy
    beachbuggy Well-Known Member
    1,931
    202
    Stock DV fitted?
  9. Benjiman46
    551
    24
  10. Benjiman46
    551
    24
    By more intermittent, do you mean the problem would happen more or less frequently than I'm having it?
    Ben
  11. s33nyboy12
    s33nyboy12 Well-Known Member Audi RS5 Owners Group Navarra Blue Classic
    1,496
    212
    I just wanted to add you have a yellow spring in forge dv running standard boost.......... I'm no expert but always been told that yellow is for 22 psi plus. Therefore your dv not operating correctly. I only learnt this 2 weeks ago when I went to jbs Chesterfield and he told my mate off for it, lucky we were there to get his mapped lol!
  12. Lemon S3
    Lemon S3 Alex
    1,390
    41
    Standard boost for an S3 is 1bar (15psi). So something is not right, my guess would be boost leak but you've checked that right?
  13. Paradox1
    1,833
    88
    as it didnt happen all the time,theres no fault code for the n75 so may be worth replacing.not meaning to sound underminding but may be worh checking the tip is secured tight to the turbo and that all inlets of the tip have clamps on them.
    Your not even near me so i cant get your car scanned
  14. <tuffty/>
    21,874
    4,201
    I would check if you have fitted the TIP over the billet piece properly... seen this a few times before... did you use sealant on the billet when fitted to the turbo? if you hear a hiss from the intake it could be a leak...
  15. Benjiman46
    551
    24
    Ok, I'll check that thanks, I used some 300 degree silicone on the billet to the turbo and turned it to smear it so I'd like to think it's sealed lol I'll check all the jubilee clips to start with :)
  16. badger5
    9,599
    2,060
    stock boost is 0.8bar on S3... 11.6psi, call it 12psi...
    if its dropping to 9psi that seems low.. 5psi is limp mode of some description..
    fault codes? got vagcom?
    summats not correct here... and not tip related unless its got a leak from fitment somewhere.
  17. Benjiman46
    551
    24
    Hmm :/ Well I did think 9 was a little bit low. I haven't got vagcom no, but will have to get it plugged in somewhere.
    I've checked the TIP and all seems well, all the clips are tight and the billet adaptor is secure and the tip is well secured to it. Ever since I knew what it boosted to (when I fitted the boost gauge) It's boosted to 12psi then dropped to 9 or 10. What could be making it boost less? I've tried unplugging the MAF and that makes no difference so it's not that.. I have recently given it a full service, oil filter, fuel filter, ultrasonic cleaned injectors and FPR, fuel treatments, the lot and it still boosts the same..
    Might just get it mapped and have done with it lol
  18. s3mad_dude
    s3mad_dude Noggies ruuuule!
    619
    79
    With your turbo boost pressure (standard map) I would have expected you to have a green spring in your DV. I have a spare one that you can have if you need it. Just send me a PM. It came with my 007P.
  19. Benjiman46
    551
    24
    I have got the green spring as I got green, yellow and blue with my 008.. But it's absolute **** IMO, I put the yellow spring in when I first got the 008, and it ran fine. Somebody told me that the yellow is no good for a standard S3, so I put the green back in, and it ran soooo **** I swapped it straight back. With the green spring in, it felt like it wasn't boosting :/
    I will however swap it back to see if it makes any difference to my problem or stop my "warble" when shifting at very high revs, and report back.
  20. Dani_B19
    9,381
    403
    Wouldnt bother, i tried running a green spring in both my 007 and 008 and car ran like ****e, yellow straight in and ran spot on.
  21. Benjiman46
    551
    24
    I'm glad you said that... I recon APY engines are more different to BAMs and AMKs than everyone thinks.. I know exactly what you mean about the green spring. Mine ran like **** too.
  22. Danman1
    Danman1 Thorough noob
    342
    19
    Is your car mapped or standard? I ask because ive just fitted my B5 TIP (went straight in with little cutting required, excellent piece of kit!!) and my 007p and I have the green spring (which I thought was for stock cars?). Do I need the yellow?
    Car is a BAM 2002 S3
    Dan
  23. Dani_B19
    9,381
    403
    Haha they do seem to have their little querks to them.
    Yeah dan my cars standard but its stage 2 speced and runs 15psi and pulls nearly as good as my mates remapped s3, id ft a yellow spring, greens fine for the golf/a3 turbos but for the s3 id always say yellow even if not mapped.
  24. Benjiman46
    551
    24
    What mods do you have for stage 2 spec mate? And how come it boosts so high for standard map?
  25. Dani_B19
    9,381
    403
    B5 v2 tip, full 3" tbe decatted exhaust system, large jetex cone filter, de-resonated forge charge pipe, welly fmic, ported inlet manifold with v6 tb and enlarged dv relocation kit. The car pulls like a train mate, that and the quick shift gear chnages it about keeps with my mates remapped s3.
  26. Benjiman46
    551
    24
    Thats awesome mate! What does that non resonated hard boost pipe give you? I've been interested in one for a while :p
  27. Dani_B19
    9,381
    403
    Well it only cost me about £20 so was a bargain, just seemed to allow the turbo to spool that bit faster and seemed to smooth the car out a bit, but i was running the oem charge pipe withot the baffle and i dont think the car liked it.
  28. actualeddie
    actualeddie Member
    211
    just a quicky while you're on springs, does the Forge Splitr take them too? I'm running one (came with the car), gonna change to 007/008 soon anyway.
  29. Lemon S3
    Lemon S3 Alex
    1,390
    41
    Its going to have springs as well but what size i don't know. Id sell it n get a 007 or 8 asap.
    actualeddie likes this.
  30. <tuffty/>
    21,874
    4,201
    Just do that...
  31. Benjiman46
    551
    24
    The Forge SplitR is officially the worst thing forge have ever sold for the 1.8t. It's like saying "by putting this piece of paper in between your face and a gun, it's ok to shoot it"... It's daft.
    Rant over lol
  32. Benjiman46
    551
    24
    Ahhh ok, How come it's baffled anyway? Surely the sound of the boost building up in the system is an exciting entity to have on a "sports" car? Typical Germans though I suppose haha
  33. <tuffty/>
    21,874
    4,201
    Its an Audi not a Renault :)
    Benjiman46 likes this.
  34. Benjiman46
    551
    24
    Very good point... lol
  35. Dani_B19
    9,381
    403
    As said and no i wouldnt debaffle it if i was you, total ballache and hindered the car if anything, the forge on the other hand like said was worth it.
