Sky+ Hard drive upgrade
AndyMac May 31, 2007
  1. AndyMac
    AndyMac Moderator Moderator
    9,832
    46
    Just upgraded my old 20GB DRX180 Sky+ box. Absolute piece of ****.
    I now have a Samsung 250GB drive FDB installed (£45 delivered from dabs.com), over 200 hours of space and much quieter thanks to the Fluid Dynamic Bearing on these drives.
    Installation is so easy, took me 10 minutes, no PC needed or anything. This site is very helpful:
    http://www.freenetpages.co.uk/hp/jerome/sky+hdupgrade.htm
  2. rowansbank
    rowansbank Member
    87
    What about the warranty? I understood that you couldn't swap out the HDD withou breaking a seal that said 'warranty void etc'?
  3. rowansbank
    rowansbank Member
    87
    Whoops - misread your post :asskicking: - thought it was a Sky HD unit! Done it myself on a Sky Plus and if I can do it anybody can!
  4. AndyMac
    9,832
    46
    There's no seal on the non HD boxes, my warranty ran out a long time ago.
  5. rowansbank
    rowansbank Member
    87
    Yup - as i said "Whoops - misread your post - thought it was a Sky HD unit!"
  6. AndyMac
    9,832
    46
    Why worry about the warranty anyway, when the only other option is to buy a new box from sky?
  7. madvw
    madvw Active Member
    2,489
    gonna have to do this on the HD box soon... The hard drive in the HD box is useless for recording more than about 13 hours of HD!!! It's suprising how quickly it fills up..
  8. rowansbank
    rowansbank Member
    87
    Well I have heard that some devious types will swap out the larger HDD and put back the original before calling Sky for a repair or replacement - which, last time I did it :icon_thumright: cost just 50 squid for a new box! Can't do this with Sky HD box cos there's a seal over one of the screws that has to be removed to access the HDD.
  9. C_Audiboy
    C_Audiboy Vroom Vroom
    822
    On the Sky+ box, I've noticed the USB port on the front. Is it possible to copy recorded programs via this port to a memory stick or USB HDD?
  10. rowansbank
    rowansbank Member
    87
  11. Caesium
    Caesium My BM is fixed! VCDS Map User
    4,879
    My Sky+ box sometimes stays running even when its turned off (red light showing) what a pain in the ass!
  12. s8craig
    1,753
    56
    I just put a 1TB SATA disk into my Sky HD box, what warranty?
  13. rowansbank
    rowansbank Member
    87
    That's the way to do it! What brand did you use? No noise issues?
  14. s8craig
    1,753
    56
    The only 1TB disk is the Hitachi Deathstar, you can use the tools to make it acoustally acceptable, but as mine is remote from the lounge, it was not an issue.
  15. Caesium
    4,879
    What speed is it? 7200rpm?
  16. s8craig
    1,753
    56
    I guess it is.
  17. Caesium
    4,879
    Been watching too much Star Wars? Its Deskstar...lol
    Clicky
  18. s8craig
    1,753
    56
    The old nickname for these IBM/Hitachi drives was "deathstar" due to the high failure rate that they had.
  19. Caesium
    4,879
    OIC
  20. bena3turbo
    bena3turbo Genuine Dude
    91
    i have regular sky digital in my bedroom and sky+ downstairs. would it be possible to replace my sky digital box for a Sky+ box? (so id have sky+ upstairs and downstairs)
    cheers fellas
  21. s3_tny
    s3_tny Member
    91
    yeah it is but you'll have to have a 2nd cable run to your bedroom from the dish like your main room and a double bonus is your subscription wont be upped but you'll have to buy the box
  22. AndyMac
    9,832
    46
    Should work but you'll only have one LNB input unless you run a new cable, so you couldn't watch one channel while recording another, but no big deal you can still pause/rewind etc.
  23. mitch78
    mitch78 Active Member
    2,350
    :thumbsup:
  24. Caesium
    4,879
    Which 1 is it and how much?
  25. Niknak
    Niknak Member
    867
    well my new hard drive arrived today thanks andy, and all done really easy to do even for a novice!
  26. Bash_A3
    Bash_A3 Member
    233
    Any links for upgrading my HD box?... or a way of reclaiming the space reserved for anytime-TV?
  27. rowansbank
    rowansbank Member
    87
  28. rowansbank
    rowansbank Member
    87
  29. scontini
    scontini New Member
  30. s8craig
    1,753
    56
    Not quite true, I have a 1TB drive in my HD box, no problems at all. Fitted it about 4 months ago.
  31. mitch78
    2,350
    :thumbsup:
  32. mitch78
    2,350
    :thumbsup:
  33. s8craig
    1,753
    56
    Hitachi 1TB SATA drive, cost around £270 when I bought it.
