skoda octavia vrs high timing pull 3rd gear run
vrsjaw May 29, 2012
  1. vrsjaw
    vrsjaw New Member
    13
    Ive just done some logs on my mk1 VRS, From what I can see boost and MAF look ok. TIming looks high though? What can cause this? Ive read anything over 6 is bad? Car is 100% standard. Ive attached logs of 115,020,003 and also 118,031,003. Can anyone shed any light on the issue? He has had a problem with revs not dropping when changing gear thats why we did some logs.this was done by a friend...av changed coil packs and plugs.......any info would be greatfull Attached Files
  2. stu_m
    stu_m Well-Known Member VCDS Map User
    1,440
    Revs not dropping could be the clutch switch if you have cruise and it works your switch is fine if it doesn't then its buggered
  3. vrsjaw
    vrsjaw New Member
    13
    i dont have cruise controll..but does the car still have it
  4. vrsjaw
    vrsjaw New Member
    13
    can any one help as its doing my nut in now and am stuck..am fitting new clutch sensor on tuesday..what else can make the car have high pull........please,thanks
  5. vrsjaw
    vrsjaw New Member
    13
    hi mine didnt have one but my mates did..him and me dont have cruise but his has the sensor so i put it in mine and the over reving has stopped....my car is still getting timing pull at 8
  6. Broken Byzan
    13,237
    465
    I'd have thought he is running on crappy supermarket fuel tbh, will mess with timing a lot due to the inconsistency of the qualtties between brands
  7. vrsjaw
    vrsjaw New Member
    13
    i use v power. but am still stuck with the timing pull..do you think a remap mite happy sort it
  8. vrsjaw
    vrsjaw New Member
    13
    cheers
