Sizes of door speakers in a 97 a4 avant
A4Paul Apr 16, 2010
  1. A4Paul
    A4Paul Member
    33
    Can anyone tell me what size the door speakers are in a 97 a4 avant,as i want to upgrade mine from the standard,and can anyone recommend any?
    Cheers Paul
  2. Izzy1
    Izzy1 Vorsprung Durch Technik
    395
    10
    most likely 10cm (4inch). due to lack of space behind the door card it's hard to find replacement aftermarket ones that are slim enough to fit.
  3. Oranoco
    Oranoco Well-Known Member
    3,970
    405
    I run Focal 5ΒΌ" components on an adapter ring in the front of my A4, tight fit but do work well. The quality of adapter rings seems to vary wildly as some I've seen are completely gash!
  4. Izzy1
    395
    10
    have you modified your door card in any way?
    i've got a facelift A4 and it's a mission trying to find some after market speakers that will fit without modifying the door card.
  5. Oranoco
    3,970
    405
    Nope, the adapter mounts to the original speaker position on teh card and the new speaker screws to that. Refitting the door card can be a little awkward with bigger magnets but not too shocking.
  6. rasA4
    rasA4 Four Rings Mafia Specialist Team V6 Audi A4 saloon
    3,287
    119
    are you looking at putting the front door speakers throught an amp? if not IMHO i wouldnt bother as when i did they sounded worse as Oranoco said some adapter rings are cr*p i bought the the Autoleads brand...
    You can make up some of your own if you have the time out of MDF as AndyMac did.
  7. A4Paul
    A4Paul Member
    33
    Yeah,i was planning on running front and rear speakers on their own amp.I will keep a eye out for a bose system as well as thats another option
  8. rasA4
    3,287
    119
    i wouldnt bother with a BOSE system, as you will have to re-wire the entire system, quite a bit of work
  9. AndyMac
    9,832
    46
    But after all that work it will sound slightly better!
  10. aragorn
    18,485
    855
    How about running the Bose speakers, but driving them via the aftermarket amp?
    Are the speakers themselves half decent?
  11. AndyMac
    9,832
    46
    Nope
