Single Xenon to bi-xenon conversion. Help...
oaky99 Apr 1, 2013
  1. oaky99
    oaky99 New Member
    hi, i have the single xenon headlights. My question is, will my new bi-xenon headlight fit straight in without changing the ballast? will i need different bulb type?
    bi-xenon headlight
  2. PH1L
    PH1L Gievf Buckets
    3,851
    40
    to fit the light that you listed from the one you had youll have to fit new front panel bumper wings and bonnet plus some control unit changes
  3. oaky99
    oaky99 New Member
    thanks, if i do change bumper etc. will my current ballast and bulbs be ok to use or will i have to change to bi-xenon ballast? my audi a3 is a 2003 8p
  4. PH1L
    PH1L Gievf Buckets
    3,851
    40
    the xenon system is completely different regrettably you have d1s style bulbs the facelift led units use d3s
  5. oaky99
    oaky99 New Member
    cheers, i bought the headlights without ballast and bulbs. So if i buy d3 bulbs will my old ballast be ok to use?
    thanks again for everything, much appreciated.
  6. PH1L
    PH1L Gievf Buckets
    3,851
    40
    the ballast / ignitor is require from the corresponding xenon type
  7. oaky99
    oaky99 New Member
    thanks, will post pics when i finally get them done!!
