Single press unlock?
weekenny Feb 27, 2012
  1. weekenny
    weekenny Active Member
    139
    51
    Is it possible to reprogram the locking to unlock all on the first press?
  2. Rastamouse
    Rastamouse Welsh Audi Nut
    398
    19
    Im sure this is possible i think i had it done on my old mk4 golf, but cant for the life of me remember how it was done! Doh!
  3. Blackie
    Blackie Active Member
    697
    67
    Yea it's done in vag
  4. weekenny
    139
    51
    My local dealer said it couldn't be done but it seems I was right to doubt them. So can independent specialists do it or can I pick up the kit to do it for sensible money?
  5. Blackie
    697
    67
    Depends what you want to spend. Always good to have the lead and software.
    Program the doors, make the alarm beep etc etc
  6. RMH1A4cab
    RMH1A4cab I'm in Cruise control
    551
    19
    Vcds I have done it, can't remember the code and I'm not home to look I'm sure someone will have it to hand.
  7. daveyb0y
    daveyb0y Member
    43
    I did this on my S3, dead easy.
    Info from ross-tech site..
    Central Convenience Controller Coding:
    State Bit Dec. Function
    OFF 0 1 Great Britain- alarm system (only with bit 4)
    OFF 1 2 flash on when arming/unarming alarm system
    ON 2 4 selective locking 1 door/all doors
    ON 3 8 activate alarm system
    OFF 4 16 rear unlocking block via speed
    OFF 5 32 locking via speed
    OFF 6 64 comfort functions with remote (adapt in ch 62!!)
    OFF 7 128 right side steering
    OFF 8 256 avant (glass break sensors in rear side-and rear
    windows (if error: safe-LED constantly lit ))
    ON 9 512 1x flash when lock with remote
    ON 10 1024 horn sounds when lock with remote
    ON 11 2048 door/window-logic ( ignition off: No open door
    el. windows works 10 min )
    OFF 12 4096 normal/????-alarm system
    ON 13 8192 No SAFE-function USA only
    OFF 14 16384 insulate-glass PR-nr 4KR/4KV
    Again, we can verify that we did this correctly by adding up all the decimal values for the bits that are ON:
    4 + 8 + 512 + 1024 + 2048 + 8192 = 11788.
    Now notice that bit 6 with a value of 64 and function "comfort functions with remote (adapt in ch 62!!)" is OFF !!! So in order to turn this ON, we need to add 64 to the original coding. 11788 + 64 = 11852. Recode the module with that number. Once you do that, the options in Adaptation Channel 62 should take effect, and you can change the value there to "fine tune" the features..
    If you wanted to add "locking via speed" (where the car locks itself as soon as you reach some low speed), you would add 32.
    If you wanted to turn Selective Locking OFF, (so the entire car unlocks with one press of the unlock button on the remote) you would subtract 4.
  8. weekenny
    139
    51
    Thanks a lot guys. How much are we talking for the cable and software?
  9. A4Ade
    A4Ade Active Member
    106
  10. RMH1A4cab
    551
    19
  11. A4Ade
    A4Ade Active Member
    106
    Apologies to Nigel - my suggestion was just the result of a quick google - no personal interest!
    (and he's cheaper, I notice!)
  12. daveyb0y
    daveyb0y Member
    43
    I got mine from NHN, proper gent!
  13. weekenny
    139
    51
    Thanks guys
