Single press on keyfob
Newbos Sep 15, 2012
  1. Newbos
    Newbos Member
    115
    Hi guys
    new to the forum, i have just bought an a4 avant (b7) and id like to change my fob to unlock all doors except boot with one press. I know it can be done as i did the same on my MK4 Golf Anniversary. I have VCDS and correct cable, can some one let me know the cable?
    Simon
  2. Newbos
    Newbos Member
    115
    That's suppose to say code at the end sorry.
  3. mikeyboy
    mikeyboy S-line
    431
    51
    Why? Whats wrong with pressing the button twice?
  4. Newbos
    Newbos Member
    115
    nothing i guess, but my preference is to press it once, and i know you can do it through VCDS, just not sure on code.
  5. hades-
    9,482
    646
    check ross tech site or search is an idea
  6. Newbos
    Newbos Member
    115
    Can't find a definite code via search and I don't want to mess it up with incorrect code.
  7. Gazthesparky
    Gazthesparky Member VCDS Map User
    217
  8. gary3306
    gary3306 Active Member
    989
    41
    as long as you write down the existing code before you do anything, then if you ferk up you can put the original code back in. As above, Ross-Tech Wiki is your friend ;)
  9. Joe_Murphy21187
    Joe_Murphy21187 S-Tronic
    1,064
    71
    You disable something like 'security unlock' I seem to remember? I managed to find it on the software, fairy straightforward stuff...
  10. NHN
    29,577
    1,779
    Please show us a log of the car.
  11. Newbos
    Newbos Member
    115
    Why do you need a log? All I need is the code for unlock with one press?
  12. NHN
    29,577
    1,779
    In order to get help on this request from myself, please provide a log of the car.
    Also if you had to read the thread fully, you would note Gaz had already pointed you to the correct site for info on the coding required.
  13. Newbos
    Newbos Member
    115
    I will provide a log as soon as i can. Im being a bit thick here, but im assuming this is the bit from Wiki i need to do
    [h=3]Channel 021: Remote Control Matching[/h] [Select]
    [46 - Central Convenience]
    [Adaptation - 10]
    Channel 021.
    [Read]
    • Choose the memory position you want the new key be matched on by entering it's number (e.g. "3" for memory position 3). Make sure to TYPE IN the number instead of scrolling up to it, otherwise you will not be able to click [Test].
    [Test]
    • Now press any button on the remote you want to match.
    • The meas. block field above will change from Not Recogn. to Recognized.
    [Save]
    [Done, Go Back]
    [Close Controller, Go Back - 06]
    Choosing the right option for 1 press??
    Simon
  14. hades-
    9,482
    646
    thats for remote matching
  15. Spr0cket
    Spr0cket Member
    114
    You're not trying to add or remove remotes - at least not to just allow selective unlock or driver or all doors.
    Coding looks to be+00004 = Selective Central Locking (SCL)
    As Nigel has suggested - if you're unclear post logs and he can advise you with confidence.
  16. Gazthesparky
    217
    No that matches a new remote as NHN says he needs to see a log of the car to check everything's ok
    It's the coding part you require once you post a log up we can help you
  17. Newbos
    Newbos Member
    115
    I see, cheers guys for the quick response. i will get the log tonight.
  18. Newbos
    Newbos Member
    115
    Here is my log
    Thursday,25,October,2012,23:07:08:32264
    VCDS Version: Release 11.11.3
    Data version: 20120401
    Chassis Type: 8E - Audi A4 B6/B7
    Scan: 01 02 03 08 09 0F 11 15 16 17 18 36 37 45 46 55 56 57 65 67
    69 75 76 77
    VIN: WAUZZZ8E47A054887 Mileage: 147290km/91521miles
    Address 01: Engine Labels: 03G-906-016-BLB.clb
    Part No SW: 03G 906 016 JD HW: 028 101 265 4
    Component: R4 2,0L EDC 000SG 8245
    Revision: --H02--- Serial number:
    Coding: 0000072
    Shop #: WSC 06335 000 00000
    VCID: 6ED9D061798C249
    No fault code found.
    Readiness: 0 0 0 0 0
    Address 03: ABS Brakes Labels: 8E0-910-517.lbl
    Part No SW: 8E0 910 517 H HW: 8E0 614 517 BF
    Component: ESP8 FRONT H06 0140
    Revision: 00000000 Serial number: 00000000000000
    Coding: 0004401
    VCID: 2C5D1A698F10169
    Address 08: Auto HVAC Labels: 8E0-820-043.lbl
    Part No: 8E0 820 043 BJ
    Component: A4 Klimaautomat 2833
    Coding: 00000
    Shop #: WSC 00000
    VCID: 6AD1DC711664C89
    Address 09: Cent. Elect. Labels: 8E0-907-279-8EC.lbl
    Part No: 8E0 907 279 M
    Component: int. Lastmodul ECE 0907
    Coding: 10001
    Shop #: WSC 06335
    VCID: 3C7D2A292C70869
    Address 15: Airbags Labels: 8E0-959-655-94.lbl
    Part No SW: 8E0 959 655 G HW: 8E0 959 655 G
    Component: Airbag 9.41 H12 3730
    Revision: 91H12373 Serial number: 0036M0G2GCRI
    Coding: 0031612
    VCID: 3B7F29357A7E811
    Address 16: Steering wheel Labels: 8E0-953-549.lbl
    Part No: 8E0 953 549 Q
    Component: Lenksáulenmodul 0701
    Coding: 02002
    Shop #: WSC 06335
    VCID: 41835BDD4B92EB1
    Address 17: Instruments Labels: 8E0-920-9xx-8EC.lbl
    Part No SW: 8E0 920 951 E HW: 8E0 920 951 E
    Component: KOMBI+WFS 4 H14 0110
    Revision: 0110 Serial number: 00000000000000
    Coding: 0006401
    Shop #: WSC 00047 210 65525
    VCID: 2C5D1A698C10169
    Address 45: Inter. Monitor Labels: 8E0-951-177.lbl
    Part No: 8E0 951 177
    Component: Innenraumueberw. 0804
    Coding: 00001
    Shop #: WSC 00000
    VCID: EBDF5975999E511
    Address 46: Central Conv. Labels: 8E0-959-433-MAX.lbl
    Part No: 8E0 959 433 CH
    Component: Komfortgerát T3B 4135
    Coding: 07151
    Shop #: WSC 06335
    VCID: 79F3F33D63C2731
    Subsystem 1 - Part No: 8E2959802F
    Component: Tõrsteuer.FS BRM 0606
    Subsystem 2 - Part No: 8E2959801F
    Component: Tõrsteuer.BF BRM 0606
    Subsystem 3 - Part No: 8E0959801E
    Component: Tõrsteuer.HL BRM 0606
    Subsystem 4 - Part No: 8E0959802E
    Component: Tõrsteuer.HR BRM 0606
    Address 56: Radio Labels: 8E0-035-1xx-56.lbl
    Part No: 8E0 035 186 AA
    Component: concert II GRO 0004
    Coding: 01005
    Shop #: WSC 06335
    VCID: 66C9A841027CEC9
    End ---------------------------------------------------------------------
  19. Newbos
    Newbos Member
    115
    i have done it myself :) once i knew what to look for it was easy :) Thanks everyone for helping.
    Just out of interest my log, its showing lots of things, but no fault codes, does this mean my car is free of faults? or just cant put a fault code up?
    Simon
  20. fossie
    fossie Member
    207
    What code did you put in buddy and where.
  21. s8craig
    1,754
    56
    Central convenience module 46
    Current code was 07151
    There was a little app called basecode that you could run and pop that code in and it tells you what options you have set and what you can change, you tick/untick the options and it shows you what the new code is.
  22. fossie
    fossie Member
    207
    You got a link buddy for that Basecode thingy
