Single or Double?
mattjarv Feb 27, 2012
  1. mattjarv
    mattjarv Member
    75
    Hi Guys,
    My Flywheel on my B7 Cab is on its way out. It jerks around 2500 revs, but is OK if you go heavy on the throttle.
    A mechanic said it would be worth me converting to a single mass instead of the normal one.
    What experience have you had? Is it more expensive? Worth doing?
  2. wattsy
    wattsy Member
    84
    I would appreciate some more info on this too as my clutch is naffed and want to know if its worth changing the fly wheel while im in there. either replace the dual or go single. will check back and if I find out more will add.
  3. itsmeagain
    itsmeagain 1.8T Sport Cabriolet
    434
    I recently went thru this too, I opted for another dual mass flywheel and clutch. Hurt my wallet but drives like a new car now.
  4. mattjarv
    mattjarv Member
    75
    How much did you end up spending in total? I am not sure which is the cheaper option. Single or Dual?
  5. Fahim
    Fahim Member
    278
    Is your car a 2.0 TDI?
    If so good luck finding a single mass flywheel!
  6. mattjarv
    mattjarv Member
    75
    They now do them for 2.0 TDi's, but only recently. This is why I asked as I now have two options! But I am not a mechanic, so I have no idea whether or not there would be a huge amount of difference or what the difference is?
  7. scotty76
    scotty76 Well-Known Member Team Phantom Audi S4
    2,869
    1,523
  8. mattjarv
    mattjarv Member
    75
    I think I am just going to go for a Duel Mass Flywheel as my car was always good before it started slipping.
    I have been quoted about £200 for the labour if I can source my own Flywheel. They wanted to charge me over £400 for one! Anyone know a good place I can order one and take it with me to the garage?
  9. itsmeagain
    434
    The difference in price wasn't a lot, I will dig out my invoice and let you know
  10. mattjarv
    mattjarv Member
    75
    Well I have just come back after having a dual flywheel fitted. And I still have slight jerking in 3rd gear around 2 1/2 thousand revs. They think that I might have a clutch problem now... this is getting so bloody expensive!!
    Do you think it is that or something else? Before the car jerked in all gears around the same revs unless you gave it some beans and it glossed over it, now 3rd gear only jerks.
    Thanks!
  11. gavsman
    gavsman Member
    379
    Best practice is to change clutch & flywheel together, not sure why your garage told you just to have a flywheel changed......hang on ofcourse I do - more money for them in labour!
  12. hades-
    9,480
    646
  13. mattjarv
    mattjarv Member
    75
    ^^^ That's what I was thinking!! I now feel like going to another place for them to do it just out of principal.
    So would you say it is the clutch causing the above problem?
  14. wattsy
    wattsy Member
    84
    I have had a couple of quotes for the conversion kit clutch kit and solid flywheel and that comes to £425 for parts alone??? fitting clutch with dmfw was about £455 garage were quoting about £700 with labour!!!!
  15. NHN
    29,295
    1,701
    Single adds more vibration, hence why many opt for a new of the same, so upto you but as Bez says, why they didnt do both is beyond me aswell.
  16. mattjarv
    mattjarv Member
    75
    It's very annoying. I have driven a few more miled since my last post, and it hardly slips at all at the minute, but I know at some point I will have to do this all over again.
    Anyone got any info on good clutches to buy? Saw an LUK one for about £130 which I thought was pretty good value
