Single mass or dual mass fly wheel S3??!
chay Oct 14, 2013
  1. chay
    chay New Member
    25
    Sorry if this has already been covered but just wondered what option you guys went for!! Also what are the pros and cons of both?! Any help will be appreciated as I'm abit of a novice :)
  2. S.
    S. Well-Known Member Team Ibis TFSI Owners Group Audi S3 quattro Manual
    1,947
    509
    single mass loba/sachs over here. it's a bit louder, pedal is a bit harder too. sometimes there's rattle, most of the times there isn't. pros: it can handle a lot more power and abuse.
  3. gilberto
    gilberto Member
    156
    Went the single mass Loba/Sachs combination too. Basically as S. describes above. It is a fairly heavy clutch not ideal for sitting in traffic stopping and starting. The rattle on idle doesn't sound healthy. Apart from those things I'm glad I chose it, great bite in the low gears.
    S. likes this.
  4. S3Alex
    10,467
    4,519
    Depends on what you want,and how you treat a clutch.
    If you want to retain the stock feel,then the Sachs organic and LUK DMF will cope with up to and maybe a bit over,400lbs.
    It will not,however,cope with a lot of drag style starts.
    The Loba/SMF is tougher,but there is the harshness aspect,which isn't bad,but will be noticeable at idle.
  5. s3_sid
    s3_sid Active Member
    368
    35
    i just got a loba kit and the only down fall i can find is slow traffic/start stop as mine is a bit juddery when you let the clutch out , but it not to bad if you can just let it out fast
  6. DJ-S3
    DJ-S3 Active Member
    690
    43
    Loba/sach here too. Have to put a little more revs on when setting off, which doesn't bother me as I like to hear the milltek anyway :D
  7. chay
    chay New Member
    25
    Thanks for the replies guys, thinking about getting the single mass flywheel and Sachs clutch just abit worried about the chatter?!
  8. s3_sid
    368
    35
    Chatter ident bad to be honest I think once I put an extra .5 of a ltr in the box it will be as good is silent ! Mine only chatters noticeably when on a reasonable slope
  9. chay
    chay New Member
    25
    That's good to know, time to get saving my pennies then :)
  10. DJ-S3
    DJ-S3 Active Member
    690
    43
    In what box? Mine only chatters on a slope too, but by engaging the clutch and letting it out again the chatter tends to disappear.
  11. s3_sid
    368
    35
    In the gearbox its a trick people used to do on the mk4 tdi's as the rattle like crazy and it shuts them up a bit so just park on a hill with its front end point up and put a touch more 6 speed Vw own oil in all other stuff is rubbish !
