Simple RNSE Problem
MrBones Jun 5, 2013
  1. MrBones
    MrBones Going Gone Bye
    Hi All
    Could some please tell me how to switch off the RNSE whenever I start my car?
    Everytime I turn the ignion on I get my CD blasting out which is really annoying
    I have tried turning the Rnse off before I shut down the car, but it still comes back on when I start the car back up again
    I'm sure there must be a simple solution to this??
    K.A likes this.
  2. JRock247
    JRock247 Active Member VCDS Map User
    662
    88
    You will need to remove the 'Ignition Pin' from the Quad Lock connector, that will stop the unit turning on when the ignition is started.
    You normally have a constant 12V+ source, so the RNS-S has memory (radio stations/settings/etc/etc) and you will also have a 12V+ switched, which powers the unit on when the car is started.
    The pin outs 'should' be on top of your RNS-E. (I thinks it's pin 10?)
  3. bmh.01
    bmh.01 Member
    291
    17
    Just press and hold the power button and it will "properly" turn off rather than muting.
    K.A and MrBones like this.
  4. fangio
    fangio Well-Known Member
    1,513
    180
    :iagree:
    MrBones likes this.
  5. jb0o
    jb0o North East Forum Moderator Regional Rep Site Sponsor VCDS Map User
    2,664
    118
    There is no ignition pin in the 8P, ignition is controlled via the CANBUS.
  6. audicruiser
    audicruiser Audi Heaven
    1,865
    +1....
    This loud volume on start up has been discussed at length before. Do a search on the forum.
  7. JRock247
    662
    88
    Was not aware the CANBUS controlled power on, learnt something new!
  8. MrBones
    Thanks all for your help bmh.01 and fangio had the answer
    It was just a case of switching the power completly off rather than just muting it
    Thanks again for your replys
  9. NHN
    29,522
    1,766
    As Jonny states, its a sole constant live with a canbus on/off signalled via the ignition switched position.
