Simple question Tyre change
ang12el Sep 2, 2007
  1. ang12el
    ang12el Member
    65
    What kit should be in the boot in respect of changing my tyre .. its as dead as dodo and need to get it off .. are there any special tools apart from the obvious that I need .There you have it simple question but has to be asked :respekt:
  2. arthurfuxake
    1,308
    Jack. Wheel brace. Locking wheelnut key. Small circle of wire with hook on the end to pull off the centre cap(16" 5 arm Aero alloys only) or a U-shaped plastic extractor tool for the wheel bolt plastic covers. Oh, and a very weak plastic treaded bar to help hold the wheel on the hub whist you insert the wheel-bolts(don't use it, it snaps off inside the bolt-hole and needs to be drilled out).
