Simple question but hey How do I know if my Diesel has an aux heater?
zollybosher Feb 11, 2013
  1. zollybosher
    zollybosher Member
    58
    Bloomin cold these mornings and my car takes ages to get up to temp - I heard someone mention their Aux heater, how do I know if I have one of these puppies ? blindingly simple and maybe obvious answer to some but hey... I thought I had the bells and whistle's spec but....
  2. Joe_Murphy21187
    Joe_Murphy21187 Tiptronic
    1,021
    67
    I remember reading in my B6 manual that if the front windscreen demister was activated at low temperatures additional fuel would be burnt specifically to warm the air in the cabin. Not sure how this works, or if it is applicable to the B7, but this might count as an aux heater??
  3. jdp1962
    jdp1962 Grumpy Old Moderator Staff Member Moderator Team V6 TFSI Owners Group Gold Supporter Team Tornado Audi S4 quattro Black Edition s tronic
    8,095
    2,543
    I have a feeling the auxiliary heater is not fitted to UK-spec cars. You usually see it fitted to models sold in Scandinavia, where the weather is properly cold for long periods of the year.
  4. B5NUT
    B5NUT Well-Known Member VCDS Map User quattro Audi A6 Audi Avant Owner Group S-line owners group
    3,680
    636
  5. NHN
    29,295
    1,701
    Login with vcds & see if it shows the modules.
    There's 2 aux heaters as such, 1 is usually fitted in the car in say countries like Norway & heats up the inside of the car prior to using in the morning, this doesnt have the car engine running just uses car fuel to run & then there's one that only works at certain times as below with car running fitted to all diesels afaik & here's some blurb:
    An electrical auxiliary air heater is installed in diesel vehicles. The electrical auxiliary air heater is a combination of a PTC heater element with an integrated control unit. It is installed downstream of the heat exchanger and provides additional heating of the vehicle interior after cold-starting the egine. The electrical auxiliary air heater directly heats the air which enters the vehicle interior. It acquires all information needed for operation via the convenience CAN data bus.
    Activation conditions
    The electrical auxiliary air heater is activated:
    - in the case of the 2C-Climatronic and Climatic: automatically via the CAN data bus; in the case of the heating system: if the occupants set the heating output to over 90% at the operating unit (analog signal),- if the water temperature is below 75°C,
    - if the engine speed is higher than 500 rpm,
    - if no load management system is active and
    - if the ECON button is not pressed.
