silicone hoses
a4quat Oct 18, 2006
  1. a4quat
    a4quat Member
    374
    has anyone put a silicone hose kit on their car, does it make a difference and how much. cheers
  2. DPM
    DPM Site Sponsor Site Sponsor
    5,009
    204
    Doesn't really make much difference, it's just that the hoses are stronger and more duriable... Also look alot better!
  3. jcb
    jcb Active Member VCDS Map User
    4,132
    13
    cosmetic unless you are upping boost significantly
  4. a4quat
    a4quat Member
    374
    any ideas on where to buy a set, to get some prices........
  5. Danielson
    Danielson Member
    704
    how about samco for a start....
  6. Dan Gliballs
    Dan Gliballs Active Member
    1,568
    SFS, Samco, or Roosesport.
    They have better heat resistance qualities than factory spec, but make not one jot of difference to performance.
    I have a Samco Y-Pipe on mine,.....all others are standard ;)
  7. jcb
    4,132
    13
    forge do some very competitive ones now
  8. docurley
    4,070
    85
    I understand that after chipping or going for the K04 setup or larger that the inlet or turbo pipe have been known to collapse and cause a restriction in flow, unlike the silicon pipes that are a lot stronger and hold there shape.
  9. DPM
    5,009
    204
    We can supply you with the Forge Silicone Hoses if your interested?
  10. Dan Gliballs
    1,568
    Yep, the very same collapsing thing happened to my Astra when the boost got wound up, so I bought this SFS one............
  11. a4quat
    a4quat Member
    374
    how much?................
  12. mac1403
    mac1403 Member
    972
    When I spoke to samco, they said they did not make a silicon hose for the facelift model. The only B5 they stated was up to 1999
  13. DPM
    5,009
    204
    Which hoses you after?
  14. mac1403
    mac1403 Member
    972
    I was looking to get the turbo intake hose.
  15. DPM
    5,009
    204
  16. mac1403
    mac1403 Member
    972
    Thats what I always thought, but it does not mention my engine code, which is AJL. I am not sure what the difference is and have been meaning to go to Samco and let them compare. All I know id the facelift engine code doesn't get mentioned on any sites, including Forge
  17. DPM
    5,009
    204
    Either way from knowing the engine code we'd be able to send you the correct TIP.
  18. mac1403
    mac1403 Member
    972
    OK, thanks for the help, when I get paid at the end of the month I will give you a bell....thanks
  19. DPM
    5,009
    204
    No problem mate, it's what we're here for!
  20. a4quat
    a4quat Member
    374
    as i started the post:wtf: can i also have a price on that hose too, also a price on a full set from intake to thru to intercooler. cheers
    p.s. my engine code is ajl too.....
  21. DPM
    5,009
    204
    :sorry: Your price will be the same as the one above for the TIP and the other pipes will need to be made up so i'll need to speak to Forge before i can give you a price on those. :thumbsup:
