Silent Alarm
gaz71 May 7, 2012
  1. gaz71
    gaz71 1.8T Quattro Sport AJL
    286
    Hi guys,
    I was wondering if there is a way of setting the alarm to be muted?
    I noticed my alarm was not sounding a while back so sourced a replacement. I fitted the replacement yet still have no audible alarm.
    Am I just really unlucky and have managed to get a duff replacement or is there a way to mute/unmute the alarm sounder?
    The lights still flash but no sound.
    Any help would be appreciated.
    Thanks in advance,
    Gareth
  2. ScottD3
    ScottD3 I want your faulty electronics Supporter Team V6 quattro Audi A8 Audi S8 Team Akoya saloon TDi
    15,164
    1,123
    You want the beep on lock and unlock?
    Its something you can code via VCDS.
  3. aragorn
    18,579
    868
    Was the replacement new?
    If not, was it the newer "A" suffix style unit, or did it look like the old one?
  4. gaz71
    286
    It wasn't a new part. I got it from a8parts. It is a newer style one, I think it has an A suffix.
    Not too bothered if it chirps on setting (although that would be good), I would rather it actually makes a noise if the alarm is triggered.
  5. B5 BIKER
    B5 BIKER Member
    266
    I GOT ONE FROM A8 PARTS ALSO, AND IT WORKS FINE - EVENTUALY.
    THE PINS ON THE WIRINH HARNESS HAD CORRODED AND GONE GREEN WHERE IT HAD NOT BEEN WORKING.
    CLEANED THEM WITH AN OLD TOOTH BRUSH AND NOW SHE SINGS TO HER HEARTS CONTENT
  6. hardhitter
    hardhitter Member
    138
    Where abouts is the alarm siren on B5's ?
  7. jcb
    jcb Active Member
    4,132
    13
    boot right hand panel
  8. BT
    BT B5 S4
    10
    I have the same problem. Replaced the alarm ecu and the siren and still no sound. But the lights still flash. Can't figure it out.
  9. aragorn
    18,579
    868
    scan the locking unit for fault codes. It should tell you if it thinks the new siern is duff.
  10. ScottD3
    15,164
    1,123
    Are theses facelift or prefacelift cars?
    Mines a prefacelift and it don't beep on lock or unlock. Its programmed from what I remember.
  11. BT
    BT B5 S4
    10
    Thanks, I'll give that a go. I take it the locking unit is accessed with vagcom?
    Mines facelift, but I think you misunderstand the problem. It's not the blip sound on lock or unlock, it's the actual alarm siren, i.e. get in the car, lock it, wait a minute for alarm to arm then wave arms about frantically to set it off.
  12. ScottD3
    15,164
    1,123
    I understood the issue but i felt i should put more than just asking a question.
