Silent Alarm
gaz71 Sep 11, 2010
  1. gaz71
    gaz71 1.8T Quattro Sport AJL
    286
    I've just noticed a sight issue with my alarm.
    I triggered the alarm while messing with the car but only the indicators are flashing, there is no audible warning.
    Has anyone got any ideas what would be causing this :confused:
    I didn't see any codes the last time I scanned with VagCom but will recheck for fresh codes.
  2. evilscotsman
    evilscotsman Space Cowboy
    1,350
    13
    im sure its to do with the settings in vag com mate, I know some other cars can have the beep disabled depending on which country code you chose for the settings, alfa beep unless you set it to australia, which is done by pressing the bonnet pin-switch 3 times then holding it till it beeps, then each press after that selects a diff country.....dunno if thats much help but check vag com anyway for codings in the immob and alarm. Audi beeps will probably be in the coding in the module, accessible from vag com.
  3. olds_kool
    olds_kool Active Member VCDS Map User
    1,089
    most likely knackered siren, very common fault
    facelift use a battery back up type and the batteries eventually leak which wrecks the rest of circuit board
    bargain at £80 from audi !!!!
    i got a used replacement from a later model from A8 parts, slightly different design but works perfectly, pretty sure it had the same part number but with an 'A' suffix
  4. jcb
    jcb Active Member VCDS Map User
    4,132
    13
    you can have mine, I took it out when the battery died and it started going off at 3am.
  5. Broken Byzan
    13,235
    464
    I am sure Aragorn has recently fitted one of these upgraded units. Aquired it from Ebay.DE IIRC
  6. gaz71
    286
    That would be great :thumbsup:
    PM sent
  7. aragorn
    17,889
    689
  8. gaz71
    286
    Silly question but where is the alarm module located on the B5?
  9. olds_kool
    1,089
    below c/l pump, offside boot compartment
    try a8 parts first, only cost £25 plus postage
    wouldnt bother with an a4 one as they arent designed to last 10 years plus
  10. aragorn
    17,889
    689
    B6/7/8 all use the same part (well the revised "A" part anyway) as do most other Audi/VW cars so you can get it from anything new.
  11. wayne77
    wayne77 Member
    76
    aragorn is there any modification needed to fit one of these newer units as mine is also silent on my 99 s4 avant, or is it just a straight plug in jobby
    cheers
  12. aragorn
    17,889
    689
    you need to swap the bracket over, but that doesnt really count as a mod as its just a single bolt :p
  13. wayne77
    wayne77 Member
    76
    cheers mate thank you
  14. gaz71
    286
    Hi have you got the part number for the siren?
  15. olds_kool
    1,089
    same as old one but 'A' on the end
  16. kressy
    kressy New Member
    Hi Im havin the same issue and have purchased a new siren .... Could someone please let me know (or with any images) the exact location on an a4 cab (2003 model) some sites ive seen have said left side rear and some right. I wanna replace it myself but just need to know where to start to get the old one out ! very much appreciated.. cheers
