Sideways into a kerb at 15mph!
Splathead Dec 18, 2009
  1. Splathead
    Splathead Active Member Team Estoril VCDS Map User Audi S3
    299
    110
    43
    Earlier today, I slid on ice into a kerb sideways on a housing estate at about 15mph - both wheels seemed to make contact at the same time (no damage to the wheels).
    Now, at dual carraigeway speeds around sweeping left hand bends, I have a high frequency vibration (not like wheel balance issues) that builds and then declines in severity about every two seconds. (when travelling at a constant speed). In a straight line there is no vibration.
    I suspect that the tracking may be out a little bit but I have been told by my local tyre fitter that they can not do a 4 Wheel Alignment.
    Could the problem be something more serious?
    Is it a main dealer job to check the alignment of all four wheels?
  2. S3 HODGE
    S3 HODGE Brown passenger seat.
    1,200
    Got away lucky by the sounds of things. Sounds like alignment....Main dealers sound pricey for the 4 wheel drive alignment, Theres a local Protyre here that does 4 wheel alignment so im sure there will be something were you are that does.
    Good luck.
  3. paddy
    paddy Audi=No fault code, no idea Team Ibis Audi S3 Black Edition DSG
    5,326
    188
    Any tyre dealer worth his salt can do 4 wheel tracking !!!!!! I cant see how he can do 2 wheel tracking without lining up against the other 2 ie: 4 wheel tracking
    Could be your wheels out of line and the tyre tread singing but more likely wheel a wheel bearing i think. Can only guess mate.
  4. S3RYE
    S3RYE Interior Next!!
    3,448
    70
    wheel bearing... whirring + vibration! got lucky! i cant understand how other s3's are struggling..? mines been sweet as a nut!
  5. Splathead
    299
    110
    43
    Booked in at a local independant for a free alignment check and then £23.50 per axle if required.
    Don't think that it's a wheel bearing as the noise and vibration would be constant under load (around the bend). Could be though - I'd not considered it.
    I'm pinning my hopes on alignment......
    I was surprised to find myself travelling sideways at that speed. It turned in to the bend without a problem and then just snapped sideways and I wasn't even on the throttle. From that point, I was just a passenger.
  6. sorry to hear mate, my symtoms sound worse i get constant vibrations, my front wheel took the full impact on its side so its either buckled or the bearing, doesnt seem like tracking as it doesnt pull left or right and the wheel when held straight keeps the car straight.
    Davie
  7. Splathead
    299
    110
    43
    OK, so yours seems worse.
    In other news, I have just tried to take the front wheel off to so that I can gain access for a 1m steel rule across the face to see if it is buckled but I don't have the tool to take the centre cap off the wheel. I have checked the foam insert in the boot and the slot where it should be is empty.
    Does anyone have a spare one (if you have posh new wheels) or know the part number?
  8. gixxer600k4
    gixxer600k4 Member
    692
    some garages can not to alignment as you need a full laser check system. do a quick search in your local area for laser alignment
  9. us a screw driver that fits in the removal hole, thats what i had to do till i got another one ha
    Davie
  10. Splathead
    299
    110
    43
    A14 tyres in Bury St Edmunds assure me that they have a full all singing, all dancing Laser system. Most of the other places that I rang said that they could not do the rear. I had visions of the car crabbing down the road and politely declined!!
    Part number is 6X0012243 - about 40p (or I might just bend a piece of wire)
  11. Mick a3
    Mick a3 Mellow Yellow
    266
    I did this in my old car to find out I had completley bent my rear axel! Baring in mind it was a fiat.
  12. Splathead
    299
    110
    43
    Yikes! :sadlike:
  13. Splathead
    299
    110
    43
    Tracking is now sorted. 1.5mm out at the front but the rear was fine.
    I've also just spotted through the winter grime that the front wheel is scuffed. Pants!
    I still have the same noise though - so probably the bearing. I'll leave it for a while to worsen (as I don't think that Audi Techies would spot it yet) and then get it changed under warranty.
    £0.43 for the Centre Cap Tool (6X0012243) if anyone needs to know for reference.
  14. Sohrob
    Sohrob Member
    351
    sounds like me although i went head on into a bollard :)
    Id get the car cleaned and have a good check for any damage, i was lucky as it only popped out the towing eye cover and scuffed the paint which pretty much polised out.
    The s3 has a strong front bumper!!
  15. mitch78
    mitch78 Active Member
    2,350
    Or just use your fingers, it isn't that difficult to get them off.
  16. mac1403
    mac1403 Member
    972
    Just use an old wire coat hanger mate
  17. DaveS3Turbo
    DaveS3Turbo Sepang Blue S3
    1,065
    I did a similar thing on our ICey road. I was going about 5 mph and the car with ABS would not stop at all. It's a bad car in ice downhill as is any car.
    David
  18. 10blazin
    10blazin HYPERDRIVE NEEDED
    3,301
    dc joint may of snapped i had vibration from mine at high speed its turns out it was the cv joint ..
