Sidelight/flash bulb change
killa_z Oct 22, 2007
  1. killa_z
    killa_z Couped Out
    180
    i am looking to change the stock sidelight bulb to match the xenon main/full beam as the sidelight is a quite yellowish colour compared to the icy white from the xenon
    i took the bulb out and checked it was a 12V 55W H7 bulb
    i understand that the same bulb responsible for the sidelight is also used for the flash beam, therefore would i need a double filament bulb?
    if anyone has done this before and can make any recommendations it would be most appreciated
  2. h5djr
    9,383
    1,727
    I think you need to look again at your lights. An H7 bulb is a single filament halogen bulb, usually 12v 55w. The bulb that is used for the side/parking lights is normally a small 12v 5w bulb in the same light unit. There is no way a halogen bulb is used for side/parking lights.
    It is possible to get a 'whiter light' H7 from someone like www.powerbulbs.co.uk. When you order a pair they usually include a pair of 5w sidelight bulbs for free.
  3. Caesium
    Caesium My BM is fixed! VCDS Map User
    4,879
    The H6W bulb used for the sidelight is a halogen, but it is only 5 watts.
  4. killa_z
    killa_z Couped Out
    180
    sorry, my mistake, the sidelight is indeed a 5w whereas the other flash bulb is the 55w H7 i was talking about, both 12v and single filament
    anyone know how to access the indicator bulbs which im wanting to change to the chrome colour which still flash orange but to match the whole headlight along with my side repeaters, seems to be difficult to access it???
  5. h5djr
    9,383
    1,727
    To get at the indicator bulb you have to remove the front wheel, remove the front wheel housing liner. Once that is removed you can get to the back of the unit and turn the bulb holder anti-clockwise to remove it.
    Sounds quite straight-forward, but I've never actually done it!
  6. killa_z
    killa_z Couped Out
    180
    will give it a try in the next day or two and let you know how it goes...
  7. MarcQuinlivan
    MarcQuinlivan Active Member
    2,539
    Anybody got any recommendations on which ones are the best to go for? Which ones give the most light and have the "xenon-style" appearance?
  8. killa_z
    killa_z Couped Out
    180
    i too have been looking, the philips or ABD ones arent looking too bad
    https://www.autobulbsdirect.co.uk/search.php?mode=search
    apparently PIAA are by far the best, but im not paying 40 odd pound for them
  9. emzino
    emzino Active Member
    1,231
    When you say Sidelight, do you mean that little bulb next to the Xenon? (Not Bi-Xenon btw).
  10. killa_z
    killa_z Couped Out
    180
    sorry to confuse all, i am looking for the sidelight which is a W5W 501 (xenon style) and a flash beam bulb which is a 12V 55W H7
    i was confused at first because both of these bulbs are in the same 'circle' if you will
    the sidelight lights up the area its in whilst the flash well.....flashes
    one click to the right with the headlight controller = sidelight
    one flick backwards from the left hand stalk = flash
    hope this clears it up...
  11. killa_z
    killa_z Couped Out
    180
    done it earlier today and was very easy, wheels doesnt even need to be taken off! instead i jacked it up about an inch off the ground to make things easier but even this isnt necessary, it does go exactly as you said, so i can confirm this! get rid of the 'egg yolk' look and put some silver/chrome ones in, job = £5 and 5 minutes!
    flash light and sidelight was changed too to a more ice blue/ crisp white insted of the stock dim yellow it comes with, sidelight may be a little tricky but you just need small hands, grab hold of it and wriggle/twist/pull carefully and should eventually pop out, flash bulb was very easy, cover popped off and simple twist and pull out
  12. Teejay
    Teejay winning the school run grand prix
    306
    FYI - it's not a 'flashlight'. This is what a soldier calls his torch.
    It is the 'main beam'. Try pushing the left stalk away from you to keep it on - useful when you're not in a city and there are no other vehicles around!!
  13. MarcQuinlivan
    2,539
    never heard it called that before..... :)
  14. latta1989
    latta1989 Member
    147
    can i just ask what did you replace these bulbs with.
    i have just bought a set of xenons and as i havent fitted them yet i thought i should change the other bulbs.
    make it a much easier job!
