Sidelight bulb holder needed
Paul_TDi Nov 26, 2013
  1. Paul_TDi
    Paul_TDi Active Member
    369
    Sorry to put it in here, but thought was my best chance at a response.
    Had my headlights out today to do prep work for fitting HIDS and discovered one of the sidelight bulb holder has had both lugs torn off it.
    Just wondering if anyone has a dead headlight knocking about they can cut out the holder with a generous amount of wire for me to solder it into mine.
    Thanks muchly.
  2. SL11CKK
    SL11CKK Active Member
    704
    37
    You don't need to solder nothing. Very easy to get the connector off. Just push the pin with a needle and it comes off.
    Now its just the matter of finding somebody who has those holders.
  3. Paul_TDi
    369
    lol you got me all excited then, thinking you had one.
    Cheers, I half thought I could do that but figured bit of extra wire encase of soldering never hurt anyone haha
  4. Mike.M
    Mike.M Well-Known Member
    2,510
    170
    Main dealer part dept or VW TPS if you have an account
  5. Mike.M
    2,510
    170
    Part number is 1J0941953
  6. Paul_TDi
    369
    Nice one, thanks very much.
    Will give Audi a buzz. Didn't even realise they would supply something like that separately.
  7. Paul_TDi
    369
    Strange, when I google that part number the part looks nothing like the part thats in the headlight.
    In the headlight it has a tab on either side that you squeeze in to release the holder.
  8. Mike.M
    2,510
    170
    That is the part as Audi redesigned it to be better to grip when pulling it and also strengthened the tabs.
    If after an original style one then a car breakers will be your best option and a lot cheaper if not free :)
  9. Mike.M
    2,510
    170
  10. madmike01uk
    madmike01uk Member
    430
    21
    let us know how much they cost, I need to get a pair.
  11. Paul_TDi
    369
    Spoke to my local audi and they didn't have one, so tried the local VW and they didn't either but quoted me just under 6 quid!
  12. Paul_TDi
    369
    Got my trusty garage to get me one through TPS in the end, 4 something plus VAT. Will post up my bill for it tomorrow.
    Strange that it's an "updated part" as my 2002 A3 had this new type fitment but my 2003 A4 has the older ones?
  13. Mike.M
    2,510
    170
    Might have been replaced before you got it and the 2003 just happened to have lasted. I think they were updated about 2005 as most of the VW group range use this design now.
  14. Paul_TDi
    369
    My A3 hadn't been tampered with as far as I know.
    I couldn't just slide the pins out as the new ones don't show the clip on the outside . I was about to slide out the old ones easy enough so cut and shut with a bit of solder in the end.
    £5.82 for the pleasure.
  15. Mike.M
    2,510
    170
    Maybe it was a design which was used on the A3 and then release to the whole range as the replacement
