side skirt (door blade)
andrecc Nov 4, 2011
  1. andrecc
    andrecc Member
    253
    hey guys you know the Grey part below the door (side skirt), is starting to peel off,
    what would i require to get it back? so everytime i close the door it stays in place.
    thanks Dre
  2. andrecc
    andrecc Member
    253
  3. jojo
    28,944
    3,598
    2 options, take them off and repair them before putting them back on or buy new ones which are £120+ each!
    I've put a new one on my driverside which cost me £80ish some 5 years ago, they have gone up in price. I've repaired my passenger one in the past, but it's coming apart again.
    Oh, and we usually refer to this part as the doorblade.
  4. andrecc
    andrecc Member
    253
    how would i repair them if i take them off? ah thank you jojo
    also do u have the part number to call up dealers regarding prices! :p
  5. jojo
    28,944
    3,598
    Below is a knackered(my) one.
    It should like like this
    Basically, the white nylon bit is pushed into the rubber bit, but over time, the rubber part shrinks and the nylon bit pops out. A quick fix is to push the nylon bit back in and araldite it, but it's a temp solution, it will come apart again over time, and in my case, 4 years or so on the passengerside.
    Don't have the part number on me, as I'm currently at work - Sorry.
    New one fitted as supplied out the box.
  6. The Doctor
    The Doctor Well-Known Member
    1,394
    189
  7. andrecc
    andrecc Member
    253
    you dont have a picture so i can see where it clips into how does it look without the door blade?
  8. Sean_S3
    Sean_S3 Member
    323
    17
    The blade is positioned on 4 pins i think and then the blade slides forward to lock it into position . If you look at the picture Jojo posted you will see the groove on the back of the blade. Removing the blade would expose the pins and the bottom of the door so I wouldnt recommend removing them.
    Ive replaced the drivers side one. Bought a used one off ebay and then had all 4 colour coded to match the car, looks good on black.
    Cheers.
  9. andrecc
    andrecc Member
    253
    i was looking at mine earlier and noticed that the white nylon is stuck onto the door but not the side skirt ive tried using adherive from halfords looks like its replacing anyone got part number?
  10. andrecc
    andrecc Member
    253
    i was looking at mine earlier and noticed that the white nylon is stuck onto the door but not the door blade is starting to come off the white nylon ive tried using adherive from halfords looks like its replacing anyone got part number? im going to try taking it off and fixxing it because the white nylon doesnt seem worn
  11. s3mad_dude
    s3mad_dude Noggies ruuuule!
    614
    79
    I have just fixed my door blade. I tried using super strong grab adhesive as it was peeling at the end of the door (nearest the door handle), and it held it on for about 6 weeks but then came away. I decided to then get one from a scrappy but they send me the wrong part so I sent it back and coughed up £130 odd for the part from the Stealers.
    If you get a new one, you will find that the part is UN-PAINTED!!! It will be primed and will look a very pale grey in colour. If you want it to look half decent, you'll need to get it painted by someone. I got my mini rear door blade painted at the same time so that they would match in colour. I went for a matte lacquer so that they weren't as shiny as before, but now I need to get the other side done because the new side looks so nice, and the other side is scuffed, old and battered! As you can see, the new part fits perfectly and only took 5 minutes to put on.
    Before:
    After:
  12. The Doctor
    1,394
    189
    What adhesive did you try?
  13. andrecc
    andrecc Member
    253
    i used Araldite Precision Syringe Halfords | Araldite Precision Syringe.
    i would push it firm for about 10mins to hold but it wouldnt it will just come back to normal loose position. also the nylon doesnt seem damage/worm as much as the pic before is just the doorblade is loose from the nylon bit but nylon is still screwed on firmly.
  14. andrecc
    andrecc Member
    253
    called up audi and they said its £156 for doorblade
    :faint: for a doorblade. could upgrade brakes with that.
  15. jojo
    28,944
    3,598
    Unfortunately, the best way to repair these is to take it off the car! Doing it in situ will not last long I assure you!!
  16. s3mad_dude
    614
    79
    Yes....definitely repair these off the car. Unfortunately I couldn't get mine off the door without trashing the strip. All you need to do is glue the nylon runner back into the recess on the rear of the door blade.
