side repeater removal
gixxer600k4 Jun 26, 2009
  1. gixxer600k4
    gixxer600k4 Member
    692
    i have fitted lamin-x to my head lights and just got myself some more for my side repeaters. instead of me going out there and scratching my car, can anyone advise me on the easiest and safest way to remove them?
    thanks guys!
  2. Lee_R
    Lee_R Active Member
    2,499
    12
    I can get mine out with my fingers, just push the repeater across to one side and pull the other end up and out, the end that comes up and out is the one with "E" written on the lens in a circle.
  3. gixxer600k4
    gixxer600k4 Member
    692
    do i push it left or right? does it then go lose and slide out?
  4. Lee_R
    Lee_R Active Member
    2,499
    12
    Whether its pushed left or right depends which way it has been put in, If you push it towards the end which doesnt have the E on the lens it can then be pulled out, at no time does it become loose.
  5. gixxer600k4
    gixxer600k4 Member
    692
    lovely, cheers for the help mate
  6. 10blazin
    10blazin HYPERDRIVE NEEDED
    3,301
    push them both towards the front of the car
  7. gixxer600k4
    gixxer600k4 Member
    692
    how far do you need to push them, they are moving about 5mm and then starts to feel really stiff, im worried about scratching the paint! do you need to get something in there to wedge it out?
  8. dc240969
    dc240969 Member VCDS Map User
    925
    is this the same way you would get access to change a bulb?
  9. gixxer600k4
    gixxer600k4 Member
    692
    yes it is, i managed to do it, i had to push it over to one side and with a plastic squeegee, wedged it out, now i know how to do it, it is very simple and safe. then there is a rubber sleeve that you pull out which houses the bulb
  10. dc240969
    925
    Ok that sounds fine. l have heard that there is another way to get to the bulb.
  11. VWAddict
    VWAddict Member VCDS Map User
    656
    9
    ...Not nessie-celery...
    -Depends how they've been fitted. Mine came from the factory with one side fitted the other way round... look for the marking as mentioned above.
    Keef
