Side mirror heating
Legend7 Dec 13, 2011
  1. Legend7
    Legend7 Member
    243
    My passenger side mirror heated mirror is not working. The driverside and rear windscreen heater both work fine any ideas what could be the cause?
  2. FranA3
    FranA3 FMDETAILING Regional Rep Site Sponsor Gold Supporter Audi A3 Team Brill Red
    7,245
    340
    could be the heating element has gone down , i got a new mirror glass of ebay cheap enough not genuine but still works fine to this day had it on there for well over a year and a half
  3. Legend7
    Legend7 Member
    243
  4. FranA3
    7,245
    340
    yeah not sure exactly what ones i bought as it was a while ago but thats the same sort of ones bud i haven't had a problem with mine , but before you do buy one have you checked if the wires are still attached on the rear of the mirror glass , just incase they have come off over time or have been knocked somehow without the wires attached the heating element will not work but the mirror will still tilt etc...
  5. Legend7
    Legend7 Member
    243
    How do I take the glass off without breaking it?
  6. FranA3
    7,245
    340
    not that hard to do really i learnt the hard way lol , under the mirrors undo the two screws (the black plastic part) directly under the mirrors it takes a bit of a wiggle to get it off (you may have to fold the mirror in to get it off) then once that is off get a screw driver between the mirror backing and the mirror where it clips onto the car (you can see where i mean on the ebay photo's) you need to get the screw driver between the clip and prise it off very gently tho incase you brake the glass , not mega hard to do but once you've done it once you will know how do them all the time
  7. Legend7
    Legend7 Member
    243
    One of the screws is damaged and I am unable to unscrew it, tried really hard but didnt want to break it all :)
    Any ideas on how I could get open it?
  8. FranA3
    7,245
    340
    you can get the mirror glass of with out taking the bottom bit off but its tricky to do , you have to get a really thin screwdriver or similar and get it in the edge of the glass but its hard to do without braking the glass , tilt the mirror glass so its pointing towards the car and there is a small space to get in the edge but i broke two glass' doing that lol
  9. Legend7
    Legend7 Member
    243
    you mean change the setting of the glass or push the full mirror in?
  10. FranA3
    7,245
    340
    just the glass leave the mirror it self alone , basically tilt it so its facing the car sort of thing but like i said i broke two mirror glass' doing it that way , the best way is to get the black plastic part off
  11. Legend7
    Legend7 Member
    243
    mmm I really dont wana break the glass however if the the wires are still connected then I would have to replace the glass anyway.
  12. FranA3
    7,245
    340
    yeah true mate lol they are easy to put back in all you have to do is connect the wires and push it into the clips it just clicks in , push the glass in the centre of it so not to stress the new/old glass on the edges otherwise it will defo brake lol
  13. Legend7
    Legend7 Member
    243
    thanks for you help. Just hope it dont break when I try it tommorow
  14. coxy8329
    coxy8329 Member
    167
    19
    Could you not identify the pins in the connector and check the continuity and resistance of the heater element with a volt meter. Would save risking the glass.
  15. Legend7
    Legend7 Member
    243
    I have no ideas about the connector
  16. Legend7
    Legend7 Member
    243
    Sorted now thanks. Did it without removing the screws and luckly no cracked glass. The wires were not attached, working now
  17. Legend7
    Legend7 Member
    243
    The trick is to press the glass in the middle at the bottom. The top pops out and then u simply pull out :)
  18. FranA3
    7,245
    340
    good stuff mate glad its sorted now
