Side Airbag Removal and Refit
Funkyfin2000 Jan 15, 2013
  1. Funkyfin2000
    Funkyfin2000 Member
    489
    Hi All,
    Anyone got access to instructions on how to remove and replace the Side Airbag on an Audi A4 B6 or similiar car?
    Need to replace mine...looks fairly easy but just don't know how much of the seat has to come apart!
    Taa
    Rich
  2. hades-
    9,481
    646
    seat or curtain ?
  3. Funkyfin2000
    Funkyfin2000 Member
    489
    Seat dude
  4. hades-
    9,481
    646
    can i as why you need to swap it ?
  5. Funkyfin2000
    Funkyfin2000 Member
    489
    Yup...igniter is faulty...got a new bag ready to fit...looks fairly simple but easier with a guide or instructions
  6. hades-
    9,481
    646
    ill find you the guide but its realy back of seat off then you can see what your doing
    did you try the wireing mod ?
    or has the bag gone off ?
  7. Funkyfin2000
    Funkyfin2000 Member
    489
    Yeah if you could get the guide...
    Have the back off and see the air bag bolted in, so release those two bolts and try and unfeed the wiring harness...
    Wiring mod already done properly with VW spec stuff....so next step is bag itself....
    The bag has the right connectors on direct to the floor so will test it first just connected to the floor plug before taking old one out incase it's not that at fault....
  8. Funkyfin2000
    Funkyfin2000 Member
    489
    ~I also have electric lumber support so theres motors etc in the way so not sure if they have to come out as well you see!
  9. Funkyfin2000
    Funkyfin2000 Member
    489
    Any luck with the guide dude?
  10. Funkyfin2000
    Funkyfin2000 Member
    489
    Cheers no need now, unless you really want to post it for others, but air bag been replaced at BVR Automotive and light now all sorted...lets see if it really is! :)
  11. Martynas26
    Martynas26 New Member
    12
    Anyone got a guide to remove that side airbag plz.... I got code short to ground and want to check all wiring in thw seat.
  12. D-xplicit Dubs
    D-xplicit Dubs Member
    62
    I have also got an issue with the airbag in my seat. if you end up getting a how to guide, please let me know. Thanks and good luck!
