Sick of this car FAULTS
Neilb1 Nov 2, 2012
  1. Neilb1
    Neilb1 Member
    178
    Went in to get the airbag light turned of only to reveal
    p1672 rad fan open circuit, circuit to ground
    00741 brake pedal monotoring
    00526 stop lamp switch
    01221 crash sensor, airbag drivers side
    I am guesing the the airbag lighjt cant be switch of because of the crash sensor, looked at the drivers side one under the bonnet and it looks ok,
    Lost what to do now
  2. chasdrury
    chasdrury Member
    362
    17
    Stop light switch is common and simple- the switch about the brake pedal.
    Can't help with the others
  3. Neilb1
    Neilb1 Member
    178
    replaced the faulty lrear lights so i guess that was a old fault as they all work, just that airbag light, looked into it and checked the side sensor and it was a little damp behind the seatbelt in the b piller, dryed it all of and will see how i get on. might swop it over for the passenger side and see if that bring the code for the passenger side
  4. hades-
    9,481
    646
    00741 & 00526 are the brake pedle switch easy fit and not alot of £££££
    01221 could be a wireing fault (has it been in a crash)
    the P1672 no idea
  5. Neilb1
    Neilb1 Member
    178
    nothing wrong with the switch though everything is working fine
    Looking at the car yes it does seem that it may have been in a bump at some point
  6. hades-
    9,481
    646
    i did a members A3 a few weeks ago it was comeing up with the same fault codes
    new switch no fault codes
    it will be on its way out
  7. hades-
    9,481
    646
    was the bag light on when you got the car ?
    if so id change the crash sensor
  8. Neilb1
    Neilb1 Member
    178
    cheers might as well get a switch for the price of them
