Show us your dyno reading!
Jimgrim77 Feb 11, 2012
  1. [Dave B]
    [Dave B] Daddy
    2,027
    145
    Nope :(
  2. aragorn
    18,612
    872
    Jim: your torque curve is a really weird shape?
    Only 289hp too? seems a bit dissapointing?
  3. Welly
    Welly VX220 SC Driver :)
    10,696
    130
    I can't see it here either....
  4. Jimgrim77
    Jimgrim77 Member
    957
    21
    Sorry guys. This is odd as i can see it fine. Uploaded and url is correct. I uploaded on my PC as my iphone got kicked off tapatalk by audisport.net. Are they doing updates today as i had to login etc...on all systems?
    I'll test again in a bit and try to re-post it where necessary. Bit dissapointed as last reading tailed off at 293bhp at 257lb torque due to clutch slipping and pre the final tweaks. It has more power now but I couldn't measure it. Will re dyno later in the week and re-post anyway as this is still a work in progress. It does sound pretty awesome though due to that xspower mani though. Best mod i've done i reckon.
  5. aragorn
    18,612
    872
  6. Welly
    10,696
    130
  7. aragorn
    18,612
    872
    Looks like hes put the photos into a private album!
  8. Jimgrim77
    Jimgrim77 Member
    957
    21
    It may do as we have tried to deliver a very linear map throughout delivery to maintain turbo/drivetrain/mount integrity. Essentially this means that maximum power on slightly later on than normal and it drives noticeably different from standard when driving as a result. However, we had made further adjustments after this reading as this was not the final map and represents very much a work in progress.
    You will notice at 6000rpm just fell away and whilst we didn't really notice at the time, we suspect the clutch slipping to be responsible for the drop. I'm hoping that it's not the clutch but when i drive home tonight, i'm going to give it the full beans and see.
    Whatever the case, at the end of the week, i'm going to be back on the dyno...with a new clutch if necessary and measure/fine tune it again. I suspect that i'm running about 305bhp now with around 280lb torque (less than i'd hoped but more than sufficient). Hopefully i'll be able to demonstrate before the week is out and report back.
  9. Jimgrim77
    Jimgrim77 Member
    957
    21
    can i change that?
  10. aragorn
    18,612
    872
    No idea, i've never used albums on here.
    l'd just upload it to photobucket or image shack instead!
    These turbos are just so hit and miss, i would be pissed had i spent all that cash and ended up at 305hp!
  11. Jimgrim77
    Jimgrim77 Member
    957
    21
    I'll upload it again later if i can get some space from the wife after some Valentine romance!!
  12. Jimgrim77
    Jimgrim77 Member
    957
    21
    It feels like more and it's how responsively that it delivers it, is what has impressed me. Like i said...i'll post the final one towards the end of the week.
  13. aragorn
    18,612
    872
    Well i've just plotted your torque graph against wellys (just eyeballed off the graphs) and we get this:
    Now ok, wellys does have a fair few extra bits on there, but thats a HUGE void between the two cars...
    What boost are you running?
  14. Prawn
    11,677
    3,677
    I can see the pics, always have been able too since Jim first posted them. perhaps it's because I'm special?
    I've spent all the money too kev and I'll end up with even less power!
    I'm fairly sure though, that like me Jim is limiting boost until he has rods to cope with the turbo's full capability
  15. aragorn
    18,612
    872
    If thats the case then fine, but it doesnt look like a steady low boost map to me, its as though the boost starts low then very slowly tapers up?
    Hmm, low boost map and boost creep perhaps?
  16. Prawn
    11,677
    3,677
    looking at the torque curve I wouldn't be surprised! Mine is a very different shape:
    Still screen shot from a video of a dyno run:
    Figures on that run are 311bhp / 277lbft at 15/16psi i think it was
    And another screen shot from earlier runs:
    305bhp/270lbft at 14psi, and the actuator run is 270bhp/240lbft at 11/12psi
    Final figures will end up lower as Niki has had to detune it with my standard rods in mind.
  17. aragorn
    18,612
    872
    yeh look at your torque, its totally flat, exactly as you'd expect from a nice steady flat boost curve, the stock engine is similar (obviously less)
    You car manages 311hp and 300lbft at 16psi and 270/240 on actuator and manages to hold those torque figures for most of the rev range...
    Jims car barely makes more than 250lbft and when it does its a tiny peak at the top.
    Something very odd with his graph IMO.
  18. Dane
    Dane Had an 8L S3, a B5 RS4 now I have a B8 S4
    4,086
    182
  19. 16Klappe
    16Klappe I <3 Panda's! Supporter
    5,795
    1,187
    That turbo's had more cocks than rambo's air rifle! :p
  20. Jimgrim77
    Jimgrim77 Member
    957
    21
    Exactly. Case and point.
    Unusual underpowered is because, and like I've mentioned in each posting...it's not my final map. We uploaded it, i went off for a drive with new settings and the clutch started to slip and I couldn't dyno it in that state properly. This was 2nd run of suspected 4 in testing.
    Because of all of the news mods...a new custom tip, the xspower mani and the Td hybrid...we've just been tinkering.
    As prawn says...without rods, I'm not going to push it too hard.
    Glad that most of you can view. Might be due to private settings. I'll sort it.
  21. Jimgrim77
    Jimgrim77 Member
    957
    21
    My clutch wasn't slipping today, so maybe it was playing up as we we adjusted the fuel timing yesterday.
    Currently, the car has been set at 310bhp and 295lb of torque. We will also be adjusted the map to boost earlier which is more to my liking. Hitting peak at 4000rpm it too late. I'll dyno again and post again with once final adjustments have been made.
  22. sambryant
    sambryant stage 2+ mk2 seat leon cupra
    167
    12
    heres my best run i had at bills, was running some crazy boost
    mbc fitted and running 1.4 bar
    i ran on the rolling road day but intake temps killed my runs (60 degrees) not good :(. i have now changed my intercooler for a much better setup :)
  23. Westy
    Westy Well-Known Member
    17,443
    1,105
    So then, can I assume that you're sig figures are taken from your 2 highest readings and not from 1 specific run ;)
  24. sambryant
    167
    12
    lol, they are max figures :D in run 1 and 2 nothing was changed, i just had out of control boost and a **** load of heat.
    on my liquid gauge the other night i made 295bhp and 290ftlb can i use that in my sig :D
  25. sambryant
    167
    12
    westy just looked at your graph and you have some serious torque :) fair play
  26. Prawn
    11,677
    3,677
    That's because Westicles is the Besticles!
  27. Westy
    17,443
    1,105
    I think it's down to my 6 month old K04. Most people have old tired K04s and when they refurb them they get them hybrid. That's the only thing I can think of creating the clutch eating toque.
  28. sambryant
    167
    12
    still thats a great result, all my above runs, the k04 is over 100k old
  29. Jimgrim77
    Jimgrim77 Member
    957
    21
    It's is so impressive! The torque has to be responsible for your mashed up clutch. Perhaps change your post caption from 'K04 murderer' to 'clutch killer'!
    What is the limit for the OEM one anyway....I can't imagine it's good for much above 270lb of torque for any real longevity. I'm already contemplating a new clutch after this weeks tweaks.
  30. Dane
    4,086
    182
    This is with a normal K04
    and this is currently ;)
  31. <tuffty/>
    21,899
    4,206
    Tut tut Dane.... :no:
    You wish your S3 had that power else you wouldn't have gone to the dark side and gone all RS4 on us... :kiss:
  32. Dane
    4,086
    182
    Yeah I do! Cheaper tyres that's for sure!
    The torque line really shows how rs4 could gain from larger ID TIPs
  33. aragorn
    18,612
    872
    The TIP on an RS4 is about 400miles long, and consists of about 12 different parts!
    Dont really see how you get that from the torque graph though?!
  34. Dane
    4,086
    182
    Yeah I know and theres not a lot of room to get big pipes in.
    I made the jump as the rs4's torque curve Isn't a million miles away from my s3's (pre b5 TIP) I'm sure the ko4s on the rs would love the extra airflow like the k04 on the s3 did.
    Anyhoo back on topic ;)
  35. superkarl
    superkarl MAN OF STEEL
    9,612
    2,481
    im loving danes torque plot on his s3! consistent for about 3000 rpm.
  36. Dane
    4,086
    182
    Cheers Bud, not particularly high figures but its there for relatively aggges
  37. superkarl
    9,612
    2,481
    better than a spike that last a split second in my opinion
  38. Dane
    4,086
    182
    Yes indeedy
  39. Jonny48
    Jonny48 New Member
    24
    Might not be as much as everyone elses but im happy :p
  40. sportstractor
    sportstractor Chugger
    2,709
    stage 2 from rtec - xs power down pipe and manifold, welly cooler, v1 badger 5 tip and jetex filter
    not as much as it could have, but slightly tired turbo gives me a good safe rod protection system :)
