Show me your induction kits please....
Ardz83 Jul 12, 2011
  1. Ardz83
    Ardz83 Member
    118
    Hi guys
    Just a quick one to see how people's induction kits look in their engine bays. I'm thinking of getting one but the last one i had on there wouldnt run right.
    The car was under powered because the maf was unplugged,i plugged it back in and it wouldnt run.
    Please could i see how you have yours and what makes you are using?
    Many thanks in advance
    Dan
  2. Bradderz_1988
    3,985
    261
    view of filter
    View of heat shield
    View of engine bay
    Filter is a k&n, heatshield is autosiliconehoses.com (ASH)
  3. Ardz83
    Ardz83 Member
    118
    Thanks for that bradderz. Does it work ok with the maf plugged in then? I got a ram air filter but wont run with the maf plugged in and runs **** with it unplugged. Any ideas??
  4. Bradderz_1988
    3,985
    261
    I'd say your maf is dodgy but the ram air filters are ment to be better in most tests than most of the other manufactures out there ie filtration,and air flow. What engine you got ??
    It runs with the MAF plugged in yes.
  5. Ardz83
    Ardz83 Member
    118
    Its a 1.8 turbo fwd 150 bhp. It runs fine with the standard airbox on and the maf plugged in. Im abit confused.
  6. steady jay
    steady jay Member
    184
    I've got a k and n induction on mine mate it runs perfectly fine. I've got the aeb engine HTH
  7. Bradderz_1988
    3,985
    261
    How are you setting it up as the ignition control module is on top of the airbox have you taken the MAF housing out of the airbox lid ??
    Have you got a pic of the filter installed ??
  8. steady jay
    steady jay Member
    184
    Only have the iPhone at the mo I can email a pic to you if you want to post it?
  9. Bradderz_1988
    3,985
    261
    On my iPhone so can't post either and the questions were at Ardz83 but hey ho lol upload it when you can get a sticky induction pic thread goin lol
  10. steady jay
    steady jay Member
    184
    Oops my bad lol
  11. 20va4
    20va4 Member
    this is mine still have MAF sensor on and runs fine ive put a passat air box heat shield on it to try and stop some heat geting to the filter [​IMG] [​IMG] [​IMG]
  12. S4_dan
    S4_dan Fire up the Quattro! VCDS Map User
    2,746
    165
    Mine is very similar to 20va4's setup. Except my filter is blue and on a 2.8 V6. Runs fine and maf is connected.
  13. Bradderz_1988
    3,985
    261
    20va4 - have you got the trumpet bit still on the maf housing? as mines tight with that removed and the tip catches the headlight slightly also do you not beleive in the cold air flowed bay theory whilst driving ?
  14. 20va4
    20va4 Member
    not sure wot u mean dont think mine has a trumpet thing lol and cold air flowed bay theory lol
  15. Bradderz_1988
    3,985
    261
    it is bolted to the maf housing as like a duct inside the airbox and this is what secures the maf housing to the air box lid !
  16. Ardz83
    Ardz83 Member
    118
    Ah my filter was the opposite way to the green one in the above pic. Tip of the filter was facing the front of the car. I guess that is wrong looking at the 2 cars here?
    The standard air box is just as it came out the factory. Yes there is plugs going to the top of the airbox and a rubber part that fits a hole in the airbox on the top. If that makes sense.
    Ps I'm on iPhone too lol
  17. 20va4
    20va4 Member
    oh i see lol no when i got the car it had another filter on it with no air flow pips goin to it. dint come with the standerd air box. do i need the trumpit thing its the AEB engine 1996
  18. Bradderz_1988
    3,985
    261
    20va4 - No as the air filter will clamp straight to the maf housing and give you a little more room .
    Ardz83 - the rubber grommet is on the maf connector harness and the two connectors on the top are for the icm all these have to be connected, in the first pic I posted you can see the icm on the air filter bracket and you should keep the metal part on as it cools the icm iirc !
  19. Ardz83
    Ardz83 Member
    118
    So did I have my filter the wrong way round? Everything was connected and it ran like a bag of sh*t.
  20. 20va4
    20va4 Member
    oh right ya not a lot of room there
  21. Bradderz_1988
    3,985
    261
    Ardz83 - it's hard to understand what you mean when you say your filter was the other way round if you can upload a pic of your set up I may be able to answer your questions basically you have the intake pipe then MAF ( make sure it's installed the right way the to bolt holes on the housing towards the rear) and then the filter make sure your ICM is connected up and also the tank vent valve and pipesbe sure to keep the icm near the cold air intake or as close to the o/s wing as poss. That's all I can suggest with no pic to go off !
  22. 20va4
    20va4 Member
    how come the ICM has to be by the cold air feed.
  23. tsporta4
    tsporta4 Member
    53
    heres my ram air setup fitted to my 97 aeb 1.8t a4
  24. tsporta4
    tsporta4 Member
    53
    it doesnt have to be but it gets hot and has no heatsink
  25. Bradderz_1988
    3,985
    261
    Iirc I've heard that it will fry the IC if it gets to hot that's why it has the metal grill looking plate to cool it hence why it's mounted to the airbox and there's a hole in the a/box to cool it !!
  26. Bradderz_1988
    3,985
    261
    That first pic is a good one to go off ardz83 similar to my setup !
  27. 20va4
    20va4 Member
    wicked i best move it to move lol cheers
  28. B5QUAT
    B5QUAT Member
    317
    13
    Just a quick question. Is the standard airbox and filter setup not good for around 300bhp (I was led to believe it was)? Why then fit an induction kit if running considerably less than that unless it's just for looks and noise? I can understand it on something running 300bhp+ but otherwise is it actually going to do any good?
  29. Ardz83
    Ardz83 Member
    118
    Each to their own mate. I had one on but now back to standard.
  30. Ardz83
    Ardz83 Member
    118
    I would upload a pic but it's back to standard now. Might have a go at refitting it after the car comes out the garage with a shiny new steering rack.
  31. tangerinedream
    tangerinedream Member
    249
    i had mine like above but i still dont think you can beat the look or performance of the standard box. as people say you can run upto 300bhp with same air box so why change it all these kits do is make your car thirsty and chavy
  32. Bradderz_1988
    3,985
    261
    I went for the cone filter as you can here the turbo spooling and sucking all that air in and also makes the 007p sound wicked ! So mine was for the sound but I think it looks better than a dusty old airbox yes they can run up to 300bhp but each to there own I suppose, I cant wait to get the Frankenturbo fitted and here that f****r spool especially when I get the 3" MAF, injectors and remap sorted :) I no it's no gt30 but hey it's hybrid !!
  33. tangerinedream
    249
    cool beans bradderrz will be very interested about the franken turbo build, be a good read
  34. Bradderz_1988
    3,985
    261
    It sure will no doubt I will come across problems and have to get some advice of you A4 guru's as im still learning lol but I will do my best to keep you all updated when it comes I will start the build thread with pic of the kit. It will be slow progress as I'm in the process of paying another holiday off but after that the mrs and i agreed I can start modding again :)
  35. Ardz83
    Ardz83 Member
    118
    What figures do you expect bradderz? How much is the turbo? Is it a bolt on or you got to change the manifold too?
  36. aragorn
    18,600
    870
    The S4 and RS4 use exactly the same airfilter and lower box assembly as the 1.8T. The only thing audi did to the box for 380hp on the RS4 was add an additional air intake which opens above 30mph (presumably so it doesnt suck in hot air from the engine bay at low speeds)
    Many big power S4 and RS4 cars are running the standard airbox, with or without a performance panel filter, so personally i dont see the point wasting all that money on an induction kit on a 180hp 1.8T. If you want to do something then stick a panel filter into the OEM airbox which will give you the same possible improvement as the induction kit, but costs half as much and stops the engine bay looking a mess.
  37. Bradderz_1988
    3,985
    261
    I'm hoping around 260-280hp when ive finished that's with MAF, injectors, FMIC and a remap but I may be wrong anything above 240-250 il be happy but I think i saw some where that the Frankenturbo with the right map/setup has pushed 300hp may be seeing things and dreaming tho lol
    It's a bolt on kit (basically it's a hybrid k04)and comes with high flow ceramic manifold and intake to take 3" MAF. Will let you no of costs when I start the build thread !
  38. aragorn
    18,600
    870
    I suspect 300 is just the usual BS dyno figures from the USA. I'd say your 260-280 assumption is more along the right lines on a nice reliable UK dyno, with the right supporting mods (ie MAF, FMIC, Injectors, 3" turbo back system and a sport cat)
  39. Bradderz_1988
    3,985
    261
    Yep the 3" exhaust system will be the first on the list as Im running the ths decat already then i will get the FMIC and then I will source the MAF and injectors ready to get it mapped. What VAG/other vehicles can I get the 3" MAF housing from aragorn ??
  40. aragorn
    18,600
    870
    as far as i know, you need one from a VR6 Mk3 Golf.
    The TT/S3 and other similar maf's dont work with the AJL sensor.
