Should I go for a 2.0TDi S-line?
razputin Feb 9, 2012
  1. razputin
    razputin Member
    122
  2. Wrath
    Wrath Well-Known Member
    1,196
    41
    Stay well clear. It'll be a BLB engine so not only will it have the balancer shaft fault, it will also have the pretensioner fault. Approx 2k to fix or 5k to put right when it goes wrong.
    In the B7 range don't go for a 2.0TDI.
  3. razputin
    razputin Member
    122
    No way!! :-(
    If that has been already fixed/replaced, would it be a goer? Or still stay well clear?
    No doubt this will have the same problems...
    http://www.usedcarsni.com/77860556
  4. CHEZ
    CHEZ moderately amusing Supporter
    4,164
    832
    well i have a BLB engined 2.0 tdi 140 s line avant! with 78k on the clock and not got any problems with my oil pump balance shaft shizzle yet!
    not saying that i wont have, but audi sold thousands of these, and only a fraction had had this overrated problem!
    (i will probably eat these words one day when mine goes tits up)
    but in reality, if you get a clean well looked after, well serviced example, i cant see any problem with them! i love mine!
  5. razputin
    razputin Member
    122
    Just like any car in reality Chez, always hear the good old horror stories! :p
    Going to see it tomorrow and you can always tell straight away if something has been well looked after. Not to say that something major won't happen a month down the road any way. Sure its always a gamble.
    It's either one of these or a Golf and I've already had 2 Golfs over the years :-/
  6. CHEZ
    4,164
    832
    just go with your gut feeling!
    they are good cars! and if you know your onions and know what to look, for you will get a good "un!
    good luck!
  7. razputin
    razputin Member
    122
    Cheers man.
    Just can't bring myself to turn to the dark side and get a 3 series, hearing all those horror stories too :p
    Plus I hate rear wheel drive cars...
  8. Paul B7
    Paul B7 Active Member
    622
    34
    Ignore Wraths advice at your Peril !
  9. CHEZ
    4,164
    832
    and ignore mine with regret:racer:
  10. Paul B7
    622
    34
    If you can find one get a 1.9tdi, much stronger engine with no major issues.
  11. Irish EK
    Irish EK Member
    92
    Listen to wrath. Far more than a "fraction" of these produced cars had/ will have this problem. Just look at the thread at the top of this section and you will see exactly what the problem is and how many people have been affected by it. You have been warned.
  12. bigrich690
    bigrich690 Active Member
    553
    44
    I got a 2.0TDi 90k and no problems but that one is unbelievably cheap if you can view it and all the paperwork is good and obviously do a hpi check then go for it that would be a right bargin
  13. Wrath
    1,196
    41
    I fully understand where people are coming from in that the internet is packed with people raising issues about their cars and not really how good they are. I must point out when the BLB issue raised it's head, there were people saying "My car has done X and it's fine, blah-blah". Some of those people have then had the problem.
    A lot of the balancer shaft issues occurred without any initial symptoms. In fact, I have received several reports where the pretensioner has snapped while driving on a motorway, engine seized immediately...you can guess the rest.
    There are always faults with all cars but this one is serious, you can't detect it and it's costly to fix and put right. Lowest mileage to have the problem was 43k! This isn't a case of a pipe coming loose or a dodgy switch of a cloggy EGR valve, this has ramifications and the damage done will mean your car will be a writeoff in many circumstances as the car value drops.
    Definitely no to a BLB (I have one!!!!)....I can't shout this loud enough, NOOOOOO!!!
    And I would guard against the later models as it has only been in the last year when problems with these started to manifest themselves. The A3 does not have these problems, possibly something to do with the engine being planted the other way on.
    I obviously can't stop you but I will wait in the wings ready with "I told you so" :friends:
  14. Gates
    Gates Member
    139
    I have a 2.0tdi how will I know if it the BLB engine or not?
  15. Wrath
    1,196
    41
    BLB was used in cars from 2005-2006. The code is on a sticker in the spare wheel well.
  16. scotty76
    scotty76 Well-Known Member Team Phantom Audi S4
    2,867
    1,522
    Wrath, does this affect other VAG cars? We have a 2008 VW Jetta 2.0TDi, just wondering if I should be looking into this?
  17. eddscott
    eddscott Member
    171
    My mother has a B7 2.0TDI 140 Auto.
    Been OK so far. Bit boring mind you.
  18. Wrath
    1,196
    41
    Not sure on the extent. A4's, A6's, Skoda Superb's, VW Passat's and some Chryser 300's are susceptible but Seat Leon's, A3's, Fabia's aren't. I suspect it's down to the engine layout. Seeing as the Jetta is a Golf with a boot, I doubt it has the fault.
  19. eddscott
    eddscott Member
    171
    Without wishing to hijack. I have a feeling I'll be looking at a TDI Avant B7 shortly too.
    It will probably be a manual 170 on an 07/57. Whats the fault history like?
  20. Wrath
    1,196
    41
    Injectors are the main one for 170's although it seems like dealers will change these for free. I don't see a lot of mentions of the 170s with balancer shaft problems but expect it must run the same thus same rules apply.
  21. Shaun
    Shaun Member
    Wrath you need to get out more! ,I bet you have a room in your house with all the walls covered in balance shaft failure info,pie charts of how many have failed mabe a cut out of the Audi CEO'S head on a dart board for not replying to your letters.
    yassa likes this.
  22. RMH1A4cab
    RMH1A4cab I'm in Cruise control
    549
    19
    Here is a link to a PDF that shows a balance shaft being replaced of a passat(I think)
    http://pics.tdiclub.com/data/3419/BHW_Balance_Shaft_Module_Replacement.pdf
  23. CHEZ
    4,164
    832
  24. RMH1A4cab
    549
    19
    Erm for anyone interested obviously your not!
    Posted link from phone!
  25. CHEZ
    4,164
    832
    well i am really! but the link wont work so...........
  26. RMH1A4cab
    549
    19
    It does now in your quote of it.
  27. CHEZ
    4,164
    832
    bonus! thanks for that!
  28. RMH1A4cab
    549
    19
    It's quite good it gives you more of an idea of what's involved.
  29. CHEZ
    4,164
    832
    it does indeed involve a lot of shizzle which to be fair is probably why this injury costs are so much to rectify if caught early and is probably way past the capabilities of most garages i know of!
    i dont know of any back street garages who would or could perform this cheaply! lol
    agreed this is a terrible problem
    agreed this is a common affliction
    but, not every blb is affected
    and not all will be,
    but many will, many wont! sods law it seems!
    at least we have forums like this to highlight and pinpoint such problems and how to rectrify!
  30. Wrath
    1,196
    41
    Of course not! I do everything electronically...my laptops full of that stuff :)
    Anytime you want me to do a powerpoint presentation then let me know :)
  31. Wrath
    1,196
    41
    To be a pedant, all BLB's *are* affected as they all rely on a piece of plastic with a shelflife so at some point it will fail. Agreed that some will last longer than others. Remember, it never gets checked, it's not part of a service schedule and no other manufacturer is dumb enough to do this, not even Ford, which is surprising.
  32. Shaun
    Shaun Member
    :icon_thumright:
  33. Gates
    Gates Member
    139
    Well I've checked mine and its a BRD code so I'm happy :)
  34. matthew999
    matthew999 Member
    145
    Sorry to dissapoint, and stop your short lived happiness, but BRD is still known to have oil pump failure due to hex rounding off in both 140 and 170 2ltr tdis.
    Sent from my HTC Desire using Tapatalk
  35. Gates
    Gates Member
    139
    Awesome just what I wanted to hear lol
  36. RMH1A4cab
    549
    19
    engine codes affected by balance shaft failure: BRD, BVF, BVA, BRE, BLB, BNA, BRF and BPW, BRC
  37. clockwork.satan
    clockwork.satan Vorsprung Durch Yer Maw
    62
    Hmm... Worrying. I just got my 2006 A4 four months ago and it's a BRE-engined model.
    How likely is it that this balance shaft failure is going to happen to every single model that apparently affected by this issue? Is it something that Audi will amend if I take it to them, as I got a year's warranty with it?
  38. Wrath
    1,196
    41
    We don't know how many area affected as it's really only been recently the non-BLBs have started having problems. Audi will not do anything under warranty unless it goes faulty and then they would.
