should i get a BOV
97_A4_1.8Turbo Oct 3, 2007
  1. 97_A4_1.8Turbo
    97_A4_1.8Turbo Member
    50
    wat kind of bov would sound the best
    i was thinking about the hks ssqv
  2. macattax
    macattax Member
    455
    You will need a diverter valve.
    Try a Baileys DV
  3. docurley
    4,070
    85
    I run a Baileys with no issues at all.
  4. S4_BY_U
    S4_BY_U New Member
    As the Air is measured on intake, you will need a recirc (diverter) Valve. Otherwise intake air measurement will be totally wrong. Same with nearly All VAG cars.
    Not sure how you got away with that Atomospheric Docurley
    Peter
    P.S Baileys recirc is what mine is running, they are pretty sweet :) around £85 I believe.
  5. 97_A4_1.8Turbo
    50
    wat is the difference between a bov and a dv?
  6. fermented
    fermented New Member
    19
  7. andybnwc
    andybnwc Member
    752
    if your just after the noise then go ahead with BOV if your after true performance then DV all the way
  8. 97_A4_1.8Turbo
    50
    thanks
  9. macattax
    macattax Member
    455
    A dv will give you performance and the noise if you either drill a hole or two in the air box or if you get a custom cold air intake. A bov as far as I know only makes the noise but does nothing for performance. Get a DV and forget about the BOV! BOVS are for chavs who want to make their crappy car sound like its a performance crappy car lol
  10. S4_BY_U
    S4_BY_U New Member
    Both Can effect performance, there is long story to tell, One lets unused pressure release into atomosphere (PSSSHHH) which is a BOV.
    And recirc reuses the air in system
    and feeds it back to the system.
    You need a DV< Recirc
    P
