Should I be worried?
AlexStanley Feb 21, 2007
  1. AlexStanley
    AlexStanley Member
    621
    We've got a new A3 2.0T S-Line - had it for about a week (the car is 3 months old).
    Everything's been fine until last night when I went to pick up my other half from the shops. Had to sit there for a while, so I had the ignition on listening to the radio.
    *Eventually*, she turned up (you know what girls are like) so I started the car and set off.
    As I did so, it took a while for me to realise the steering was really heavy - as if there was no power assistance.
    Just as it dawned on me that there was no power assistance, there was a beep and the DIS went red saying there was no oil pressure! Eeek!
    Anyway, switched everything off, waited for 30 secs and restarted and everything was fine.
    Has anybody had this before? Is it a 'feature'? Or should I be phoning the dealer already?
  2. SteveTDCi
    SteveTDCi Active Member
    1,400
    I'd report it to the dealer, at least anything does go wrong you are covered.
  3. AlexStanley
    AlexStanley Member
    621
    Thanks Steve, might be an idea...
    BTW checked the oil this morning and the levels were fine.
  4. arthurfuxake
    1,308
    Low oil level does not mean the same as low oil pressure. It might have been a blip in the oil pump(makes me wonder if the power steering pump and oil pump are linked in some way). The fault code will be stored, and the dealer will see it appear on Vag-Com.
  5. OutLore
    OutLore VOIP Dude
    1,206
    If anything like that happened to my car (as it did with the engine management light) I would call Audi Assist and get their advice. Most of the time they tell you to get the car to safety (home) and they will send a patrol out. If he says you are good to go and it then blows up you are totally covered.
  6. mfspen
    mfspen Member
    577
    10
    There is no power steering pump on the A3, as the system is entirely electrical. That is, the assistance to the steering rack is from an electric motor.
  7. klauster
    klauster Well-Known Member
    1,188
    112
    phew!
    after reading the subject heading I was expecting some story about enjoying wearing womens lingerie :)
