Should i be concerned ?
geese Mar 17, 2013
  1. geese
    geese New Member
    19
    Hi,
    VAG COM has pulled this code up , is this of any concern ? Do notice the dash flash occasionally ?
    Address 01: Engine Labels: 06A-906-033-APF.LBL
    Controller: 06A 906 033 BD
    Component: SIMOS33 1.6l 2V 00HS4582
    Coding: 00011
    Shop #: WSC 06435
    VCID: 62B7298BFD57
    WAUZZZ8L63A040143 AUZ5Z0B6245080
    1 Fault Found:
    17925 - Power Supply Relay for ECU (J271 or J363): Electrical Malfunction
    P1517 - 35-10 - - - Intermittent
    Readiness: 0000 0000
    Address 03: ABS Brakes Labels: None
    Controller: 1C0 907 379 M
    Component: ESP FRONT MK60 0102
    Coding: 0011266
    Shop #: WSC 06435
    VCID: 341B9FD31723
    No fault code found.
    Thanks!
  2. phil miller
    phil miller Well-Known Member VCDS Map User
    1,211
    166
    If it was me id order a new relay, replace it and keep an eye on the codes, it only takes the relay to not click once to throw a code
