short shifter on Audi s3
oldcar Jul 6, 2014
  1. oldcar
    oldcar Member
    238
    Guys, do you think short shifter (the one you can change settings like 20% reduction in gear shift or 40% aggressive)..
    Does this actually drop your 1/4 mile time or damage the gear box? What are your thoughts?? useless?
    yes Jason you can be the first so as Badger.. Thanks
  2. badger5
    9,472
    1,988
    you are becoming the new 8L "special" needs poster dude
    good work
    keep it up
    lol
  3. jasongtr
    jasongtr Active Member VCDS Map User
    441
    37
    haha, special needs.
    but for the record i have heard a short shift does indeed give you around 95 more hp* so yes it must reduce your 1/4 mile times
    * although I've never tested it myself
  4. <tuffty/>
    21,160
    3,837
    The diesel geek one is rubbish IMO.. all the ones I have seen look like they are about to fall apart and the fixings are always loose... had a car in that was like this so tightened the fixings up... they came loose over again over a few dyno runs and have heard tale of them pinging off the selector arms while driving..
    The Forge one appears a better choice as this only shortens throw vertically and not horizontally across the gate...
    Having driven a couple of cars with this fitted though I am not personally a fan... I guess its more personal taste but the VAG cable change is vague enough and a quick shift seems to make them a little worse..
    I had quick shift on my old Mk2 Escort and this was brilliant but cable change is not a patch on direct or rod changes...
  5. snowy
    snowy Active Member
    425
    106
    43
    If you want to recreate that experience, fit a B&M Short Shifter or its ebay rip-off copy
    Feels as close to a Mk2 Escort short-shift as you'll ever get a cable change ;)
  6. oldcar
    oldcar Member
    238
    thanks guys and Paul. Looks like no need for the short shifter , its quite useless, better off to increase boost spend money on dump pipes...
  7. limbo118118
    limbo118118 LORD
    492
    53
    iv got the forge one fitted, got it cheap 2nd hand off ebay.. i quite like it.. the way iv got it set is about 50% reduced vertical throw and it feels perfect for me, id recommend it anyways :)
  8. basil brush
    basil brush Active Member
    497
    163
    43
    1 are you implying paul is not a guy then ? and
    2 what are dump pipes ? :0
  9. <tuffty/>
    21,160
    3,837
    Been called worse to be fair :)
    You wanna hear how my 18yr daughter speaks to me (because she knows best obviously) LOL
  10. basil brush
    497
    163
    43
    i chucked away my massive encyclopaedia collection as my 18 year old also knows it all :) so yes PT i know where your coming from !
  11. Dani_B19
    9,258
    379
    Personally I love my setup and say its probably the best setup other than prawns to run.
    I have:
    Updated shifter socket (under gear stick)
    Solid shifter bracket bushes
    Solid shifter cable ends
    Forge copy front to back shifter (set at shortest throw)
    Forge side to side shifter (set around 70% shorter)
    Worth noting I changed my prefacelift ball socket cable ends to the newer pin style.
    I'd say my setup is awesome, its so tight and precise and is a massive difference from the stock setup.
  12. oldcar
    oldcar Member
    238
    thanks everyone.....this is an awesome forum plenty to learn from....
  13. 16Klappe
    16Klappe I <3 Panda's! Supporter
    5,795
    1,184
    I've got a Diesel Geek, stfu!
    It's good, a little notchy but with some adjustment it works well.
    Maybe not b&m good, but I like it.
