Short shifter installed
Road Razor Mar 16, 2008
  1. Road Razor
    Road Razor Member
    411
    I've just installed a B&M short shifter. Putting everything back together was most time consuming part because of the limited workspace in the drive shaft/housing. But it's brilliant kit, I'd definitely recommended to anyone.
    Just one problem though, the stick keeps falling downwards through the pivot (see pic below). I realise there's a retaining ring missing when I assembled the shifter as per the instructions. So far I have to lift up the stick everytime I select a gear.
    I might have to find something that sits above the pivot to stop the stick falling or find something and wrap round it. Or use jubliee clips.
    Any other suggestions?
  2. stapo69
    stapo69 All hail the mighty quattro!
    969
    Is the spring provided not enough to hold the shifter up? I found the opposite with my kit, was hard to push the stick down to get reverse, took it off after a year cos I could no longer select reverse!
  3. Road Razor
    Road Razor Member
    411
    There's no push down mechanism to select reverse because in the facelift version you just select reverse just like any other gear. There's springs provided but it's only for the pre-facelift A4.
  4. Mr K
    Mr K Member
    335
    i think that could be your problem.... my facelift i have to push down the stick.
  5. Road Razor
    Road Razor Member
    411
    So the facelift does have a push down stick. That's interesting to know.
    Anyway the instructions does cater for both types, one which have the push down reverse, and one that doesn't. So it appears that there are two types of shifts regardless if its facelift/pre-facelift.
  6. Broken Byzan
    13,237
    465
    When its pulled right up is there a groove for a clip? Its been years since i fitted mine
  7. Road Razor
    Road Razor Member
    411
    No there's no groove when pulled right up. I think a retaining ring would've fixed this problem but I'll try and figure out another alternative. Probably get some anti-slip rubber to wrap round the stick then clamp it. Thanks for your input guys.
  8. stapo69
    969
    I thought facelift and pre were the same, my mates facelift had push down reverse.
  9. Blue_Thunder
    Blue_Thunder Well-Known Member
    1,776
    33
    There was a groove in my short shifter that needed a circlip to hold it in place.
  10. Oranoco
    Oranoco Well-Known Member
    3,974
    405
    My 96 A4 has puch down revers but my 97 A4 didn't :?
    I've been looking at quick shift kits fo myine and found VAGtech do one fitted for £140
  11. docurley
    4,071
    86
    I lost my clip to hold it in place when I was installing mine so in the end I used a jubliee clip and it's been good for near on 2 years and my kit was one of thouse ebay jobs which I understand is just the same.
    The face lift 1.8T do not have a pushdown Reverse but maybe the S4's do.
  12. Turbo Lag FTW
    Turbo Lag FTW Hate those none insured you know who types
    235
    My mothers facelift requires pushing down to get reverse, as does my prefacelift, but tbh mine is kinda worn and will go into reverse with minimum effort
  13. Road Razor
    Road Razor Member
    411
    I've managed to fix the issue by wrapping sticky velcro (rough part) around the stick then clamp it with jublibee clips.
    It's amazing how making this simple short shifter upgrade makes a difference and improves my enjoyment to the car. No more wobbly long throw. :racer:
  14. billybravo
    billybravo Active Member
    1,045
    or you could just make you own :)
  15. AUDI TURBO
    AUDI TURBO Member
    577
    do they make this for a a4 1.8 turbo 1996????????
  16. billybravo
    1,045
    you can do it urself mate there is a write up on audi-world
  17. AUDI TURBO
    AUDI TURBO Member
    577
    you can make yourself that intresting
  18. nomadx
    nomadx Member
    my 99 a4 doesnt have push down for reverse
