Short shift crunch.....?
bl_1969 May 20, 2009
  1. bl_1969
    bl_1969 Roads? We Dont Need Roads!!!!
    358
    Any peeps had a short shift fitted then had crunching of gears? I saw a warning on Diesel Geeks site and want to know before I purchase. My gears dont crunch at the moment but thats because I have impeccable gear change :jester:
    Anyhows, was just wondering.
    Cheers Cheers
    b
  2. Dani_B19
    9,336
    392
    Mines quite bad but im wanting a dieselgeek shifter in the future :(
  3. bl_1969
    358
    hmmmmmm Any other peeps with them and crunching? I dont think I am gonna do it if there is Le Crunch. My ears are sensitive :keule:
    Dani_B19, is that not annoying to you? Like is it a lot of crunching or just a particular gear?
  4. Dani_B19
    9,336
    392
    Annoying as hell, it gets in the way when driving quite enthuisasticly aswell, going to get the dogbone mount fitted to hopefully try and reduce it
  5. abdus
    abdus Top Gear VCDS Map User
    1,827
    the TT one doesn't crunch on mine. It's like standard but much better with a reduced throw. Looks OEM and also a very cheap mod
  6. Dennis Moeller
    Dennis Moeller Member
    444
    Fitted the Diesel Geek kit 5000km's ago. Box didn't crunch before and doesn't do it now. In fact it transformed the gearchange. The promised reduction in throw was a bit exaturated but it is 15-20% shorter, especially horizontially. Also fitted the Powerflex dogbone (the two large square ones, not the round bushing) and that did tighten up the feel a lot. Now I can change from first to second a lot faster. If only that stupid electronic gass controller would stop taking e pills. I miss the old style cable operated gass valves :)
  7. Shy19s
    Shy19s Oil running through my veins.
    886
    The crunching is where people change before the clutch is fully down.. its just adapting to fast clutch action, they're hands move faster than there foot... Just an observation from when i let my m8 drive my short shifted civic VTI back in the day.. he couldnt hack it lol... I'm sure you'll get used to it.
  8. Olly P
    Olly P My other cars a mk2 Golf GTi
    702
    12
    I've got a Diesel Geek short shift, no problems at all! Its awesome, highly recommend getting one!
    The standard S3 gear box does seem a little rough around the edges though!
  9. Dennis Moeller
    444
    I have to agree on that. The S3 'box is NOT very refined at all. It doesn't have the slick mechanical feel to it. But it's not the worst I had either. Short shift and dog bone bushes made a lot better.
    I have to correct my previous post. The reduction in throw are bigger vertically, not horisontically. At least on mine. Didn't adjust anything when I initiately installed it - it was smack on the first time so I didn't want to spend endless hours trying to reduce throw even more...
  10. S3quatt
    S3quatt Flat Oot like a ducks Foot VCDS Map User
    652
    60
    I've fitted the Forge short shift. Looks like the OEM but has a slot for adjustment.
    No probs with crunching either.
  11. bl_1969
    358
    Right! Thats it sorted then :yahoo:
    I will get one. Think I will go for the Diesel Geeks one as there are a few good comments on this.
    I also read that if there is a syncro issue/crunch to start with then the short shift will amplify the issue..... I don't have any crunch so I think I will be ok.
    Mr Moeller, Any chance of part number for the Powerflex dogbone? I will buy you a virtual pint! :jester:
    Cheers for the help people! :respekt:
  12. Olly P
    702
    12
  13. Dennis Moeller
    444
    Here you go: PFF85-420
  14. Dani_B19
    9,336
    392
    So what does the tt part shorten, side to side or up an down.
  15. bl_1969
    358
    Cheers Dennis!
    :beerchug:
  16. Defratos
    Defratos You’re Dethpicable!!
    2,232
    I've got the dieselgeek shifter as well, but I got it because my OEM gears were a bit crunchy and very slow to engage. I've got the older version of the dieselgeek so I gotta update to see if it makes a difference........I didn't really answer your question but I wanted to give you my input either way :beerchug:
