Shock replacement
jdas03 Nov 15, 2011
  1. jdas03
    jdas03 Member
    603
    Hi All,
    I replaced my standard shocks and springs with the cheap FK AK Coilover Kit.
    Handling was improved greatly but overtime they have started to knock.
    I have read a few other threads about problems with these kits, in particular the rear ones.
    I believe it came down to a dodgy batch of shocks
    Anyway I am going to be removing the offending shocks and sending them off for replacement under warranty (i hope)
    I have decided though I would prefer buying myself a more trusted brand splashing out a little more money and sell the replaced FK's on once the whole set have been replaced on my car.
    My plans are to remove the rear shocks and replace them with something better for now.
    I have a few questions i hope someone can answer:
    - Is there a problem with having FK springs and shocks at the front and FK springs paired with a different brand of shock at the rear?
    - Am I able to use any shocks with the coilover springs i have? (the springs are height adjustable) for example could i fit billstein B8s to the rear? or will this cause problems?
    - On europerformance they list a few different brands of rear shock - billstien, Koni, KW, Weitec (Audi S3 / Shock Absorbers / Euro Performance Car Parts)
    Which of these would you guys recommend to stick on the back if any of them are suitable?
    Thanks in advance for any help and advice :)
  2. Westy
    Westy Well-Known Member
    17,438
    1,093
    Most spring/shock kits have the springs and damping rates balanced for best ride/performance. Personally I wouldn't mix and match but if you use shocks that are from a similar kit (similar lowering rate) it should be ok.
  3. Jason.s
    Jason.s Active Member
    2,879
    348
    If they replace the dodgey batch with the new type that doesnt have faults you might aswell save your money and keep them..Put the money towards one of the things in your wanted/to do list
  4. jdas03
    jdas03 Member
    603
    Well normally i would but i kinda wish i had gone for a better set to begin with.
    As if these are fragile now i'm not holding out for them being a long term solution over years to come!
    As for replacements what you are saying is if i buy dampers that work with up to 30mm lowering like the billy b8s as long as i keep within their designed tolerances i should have a good performing car?
