Shielded induction kit
Davsurfa Sep 5, 2009
  1. Davsurfa
    Davsurfa Member
    169
    Haven't got as far as I wanted to today cuz fitting the induction kit took a little longer than expected. I know it's a simple job to do, but then if I can make it harder I will. So having removed the airbox and MAS
    I went down the usual route of fitting the adapter plate
    Then the cone filter
    Then I took it all off again. Quick trip to the local newsagents for a couple of tins of Relentless and a cardboard box. Spent the next 2 hours cutting, bending straightening and taping the cardboard to make a template. Then cracked out the trusty old angle grinder and attacked a sheet of galvanized steel(1.6 mm) that I aquired from my works(cheers boss).
    Once again I trimmed a little here and a little there, then drilled a few holes so I could bolt it together(cuz welding galv can be a right b*&%h) and then bolt the MAS in place.
    Added the cone filter and slotted it all in place. Made a small bracket and mounted it using the original airbox bolts and mounting points and there I have one shielded induction kit.
    Oh yeah then I fed the cold air feed up and in place after the pic was taken but that now sits down the side of the battery, also there is still the original feed that went in to the airbox so the air flows in from both sides. The idea was not to create an airbox with a cone in but more to shield the cone from the engine heat.
  2. Dani_B19
    9,112
    346
    Nice effort mate.
    Dont want to spoil your high but your cones still going to suck hot air in unless that sheild sits and forms a seal with the bonnet! Also the piece of stell running down by the battery towards the fron of the car, you should of tuck behind the battery :thumbsup:
  3. Olly P
    Olly P My other cars a mk2 Golf GTi
    702
    12
    yea, I think most people agree that using the standard air box is better than a induction kit!
  4. Davsurfa
    Davsurfa Member
    169
    Fair comment, but as I said it wasn't the intention to create a sealed box. To be quite honest it's a 1.6 so it's not gonna make much difference what I do to the engine it'll never be a quick car. The idea of the shield is to keep the worst of the heat away. Also why should it run behind the battery rather than down to the front? I'm curious now. Oh yeah and you ain't spoilin my high LOL.
    And in reply to Ollie P, I'm not sure performance wise leaving the stock box on would be better. I understand that the car is setup to run a stock box but I found that when changing from 1st to 2nd and from 3rd to 4th there was a noticeable flat spot in the rev range which has now disappeared. It does seem better at the lower end of the rev range. Although I'm sure the fuel consumption will suffer.
    On the plus side I do get the sound to boot :eyebrows:
  5. Dani_B19
    9,112
    346
    To help keep it closed off and form a better protection from the engine bay heat and to also help feed the cold air from you air feeds towards the cone.
    Well if its a 1.6 then fair play, didnt know what you were running tbh pal.
  6. Davsurfa
    Davsurfa Member
    169
    The joys of vehicle modification is just this :) Someone mods their car then everyone can see different ways of doing it better then the mods get modded. So now(well maybe tomorrow actually) the shield will come off and be changed a little bit. I have 3 more pieces of galv at home so I can always start from scratch. I do appreciate anyones input though, except Impreza drivers!!
  7. Dani_B19
    9,112
    346
    Yup totaly agree, creative critism is always welcome. Good luck with altering it.
  8. rossbrownlee
    rossbrownlee Ross_S4
    719
    mate did you seal all those tin edges with rubber?? I was just looking at your red (ICE??) cable and the cable down to your starter motor (i think it is)?? ever seen a short from auto electrics? ouch!
  9. Davsurfa
    Davsurfa Member
    169
    LMAO!! Yes I have, I used window trim from and old 4x4 I had. I took the last pic before the tidying was done. All the edges are now covered cheers.
  10. AudiMafia
    AudiMafia Member
    403
    13
    in A3 1.8L 2000 what difference would it make ?
    thx
  11. Olly P
    702
    12
    None, probably make things worse if anything! Try doing a search on this site for induction kits
  12. Davsurfa
    Davsurfa Member
    169
    Tbh I really couldn't tell you, all I know is how it made my car respond. I can't see how it would be detrimental but then I've never fitted one to a 1.8 Audi. I was warned about fitting one to mine but did it anyway and I'm pleased with the outcome. That said I've seen more than one post saying they have fitted one and lost power.
  13. Paul @ Unit 9 Remaps
    Paul @ Unit 9 Remaps Site Sponsor Site Sponsor
    2,035
    131
    you would loose power and for some reason beleive it hasnt made a difference to yours but noise, and that maybe the reason you think its made a difference
  14. Davsurfa
    Davsurfa Member
    169
    I'm sorry but what a load of ****! Actually I can't hear it unless I'm absolutely caning it. I've noticed it drives differently and so did the missus, she didn't know I'd fitted it cuz I did it whilst she was in work, then I asked her to drive it to see if she noticed any difference. In her words she said "It's more responsive and seems to want to go now."
    But I'm sure that whenever anyone makes any modification to an engine it is all just a waste of money and time unless everyone makes the same mods then everyone must get the same result. I'm also pretty positive that companies such as K&N, Pipercross, J Intakes and the such are all lying when they make such claims as being able to increase the responsiveness of any engine.
    I'm quite aware of how my car responds after any mods I do to it. I'm not a 17 year old oik who thinks that a loud pipe makes a car faster, at 34 I'm a bit beyond being impressed by noise. If I really wanted to go fast I go back to riding motorbikes. I don't care how much bhp any Audi makes I had bikes that would outstrip any of them so when I feel a difference in the engine I'm capable of noticing it.
  15. Matt82
    Matt82 Active Member
    2,365
    agree. also redline mag did a dyno test on your type of engine where a cone lost 15bhp
  16. fran-s3
    fran-s3 Active Member VCDS Map User
    1,103
    You did at work?? I'd love to be able to mod my car at work and get paid at the sametime, sounds like you've got it made.
  17. Davsurfa
    Davsurfa Member
    169
    The shield is actually coming off this weekend to be changed a bit but either way I'm still happy with the outcome.
  18. Davsurfa
    Davsurfa Member
    169
    No no, my God I wish!! My Queen was at work, I was sat at home on saturday doing it. On the plus side though I do get as much free steel as I need in various thicknesses and profiles and sheet cuz I work for a supplier.
  19. AudiMafia
    AudiMafia Member
    403
    13
    i like what you have done, looking to do the same otherwise K&N wouldn't claim what they have claimed about.
  20. Davsurfa
    Davsurfa Member
    169
    Good man DiKapo!! Think like the good Dr Pepper "What's the worst that can happen?" If you do find that you lose power put the stock box back on and flog the induction kit on ebay. I just find it odd that the VeeDub boys swear by them along with most other people who mod cars but the Audi boys seems to hate them. Bizarre!
  21. Paul @ Unit 9 Remaps
    2,035
    131
    been a veedub lad - full on vag boy all my life and dont swear by cone filters especially K&N as for the oil reasons, and agree with matts post, not having a go, just stating some facts,
  22. 1animal1
    9,978
    the problem isnt slating a modification...the issue here is that other members have tested their cars on RR's with the airbox and without any restriction (straight feed to the engine or turbo - no filter) at all let alone a cone filter...the results were impressive (in favour of the box)which is one of the reasons why the cones arent favoured here..... I dont think the 1.6 has the same airbox as the S3...the S3 has a 4" feed, whereas the 1.8TQ has a 3" so theres a difference right there...id guess the 1.6 may be 3" or smaller.... either way it may be a different set of scenarios...that said if it is roughly the same design as the S3 then my thoughts would be either seal the cone in or forget it.... heat will always be sucked in from the none sealed engine bay in addition to the cold air from the feed...especially under harder acceleration, this heat would be virtually none existant with the standard airbox as it is infact sealed.....
  23. 1animal1
    9,978
    and K&N have been disproven a million times on here with their cone set ups on various cars..... it is pure sales drivel, if you choose to be sucked in, please do so quietly as the amount of evidence on this forum alone proves that they talk ****
    for the record the K&N panel filter is supposed to be a good upgrade if you want a little more noise
  24. Davsurfa
    Davsurfa Member
    169
    I haven't at any point claimed any increase in power, just that the car feels more responsive. Also I'm still a little stumped by the obsession with noise making people think the car is then faster????
    On the plus side of this thread I have indeed learnt that if I make any form of modification to my car I'll be keeping it to myself. If any of the Moderators on here would remove this thread so that any newer members don't make the same mistake. Also as an update on the rules maybe a small note stating that unless someone owns a rolling road they shouldn't even attempt to make any modification under the bonnet. Who'd thought anyone who dare to come on this forum, or any for that matter, would be stupid enough to even think they'd be capable of noticing any difference in how their car feels. Clearly it's best to just wash and polish the car as long as it's using the Audi-Sport.net approved equipment.
  25. Westy
    Westy Well-Known Member
    17,443
    1,103
    Mate I take my hat off to you for knocking up this mod and sharing it with everyone, this is what a forum is all about.
    I know there are a lot of people here that share the same opinions about certain mods without actually trying them for themselves. Its all about trial and error. If you've cleared a flat spot in your rev range then to me that is a worthy mod.
    I'd say most owners here are S3 owners and they sometimes forget that different mods work differently on the other 8L platforms and start preaching about what does and doesn't work.
    Dont be put offby negative comments because what you've done here may help out another 8L 1.6 owner. Just let it run off your back mate and remember what you've put in your sig D.I.L.L.I.G.A.F.
  26. Olly P
    702
    12
    lol
  27. 1animal1
    9,978
    can i just add that my comments weren't supposed to be negative...they were meant to point out why you have had the comments that you have had...... im all for trying something new and i cant see myself why people want noise either......
    your car may be more responsive, or at least feel it....but in my mind the logic suggests that you have detuned your car based upon some pretty interesting facts (not theory) - im sure you would want someone to tell you if a mod was going to knacker your car!! yet you complain when people pipe up with logical facts.... if all you wanted was encouragement then just ask and im sure people wont share their views which is afterall what a forum is about
  28. Ess_Three
    Ess_Three Active Member
    5,383
    14
    Logic suggests what physics confirms - hot air into an internal combustion engine will makle less power than cold air, if properly optimised.
    That's not just subjective thinking...it's gas laws and physics.
    I applaud the work that's gone into the mod...but it strikes me as a tad unfair for someone to re-invent the wheel (badly) and then get all defensive when presented with simple facts, that perhaps their interpretation of the wheels isn't actually as good as the original.
    In this instance, the underbonnet temperatures are lower than on a turbo'd car - but still warmer than ambient...so it may make a tad more power top end, but will almost certainly be making less just off idle.
    Horses for courses...
  29. AjM
    AjM Living in Blissful Ignorance
    330
    Rather than go over what has already been said, personally i will always go for either a BMC CDA (if you have £200 odd for an air box) or standard air box with a BMC filter and maybe if ness an extra cold air feed as well as the standard.
    The latter is what i am doing to the S3 as it currently has a cone filter. /2p.
  30. Paul @ Unit 9 Remaps
    2,035
    131
    not everyone is going to have the same opinions, therefore if you cant take other peoples opinions then i dont think a PUBLIC forum is for you, not everyone agrees with each other in life, take it on the chin like everyone else does, ALSO i think you made a good job of the heat sheild etc, nice work, but still all my previous post stand.
  31. Davsurfa
    Davsurfa Member
    169
    Westle, I take your advise and my thoughts turn to my signature which is now my opinion. LMAO!! My next mod is to rig up a hairdryer under the bonnet to see just how much I can detune my car and knacker my engine LOL!!
  32. A3Tom
    A3Tom Smell my finger.
    3,504
    14
    Mate, no ones having a pop at you.... just expressing an opinion. Its a public forum so you cant get all shouty when someone offers an opinion you dont agree with.
    For what its worth, I ran a cone on my car and it was ****... it stayed on for a week and I returned to a stock airbox with a panel filter in it. All it did was create a load of noise and suck up hot air, the car WAS slower. however thats on a turbo motor. I have run conest etc on N/A motors and not had the same problems, car picked up quicker etc and was better at top end.
    If you like it then its all good, its your car after all.
  33. Davsurfa
    Davsurfa Member
    169
    Not getting all shouty and to be quite honest I can't be doing with it all. Like you said it's my car and if I do something to it it's my choice. I'll refrain from responding with any sarcastic or defensive comments.
  34. Paul @ Unit 9 Remaps
    2,035
    131
    exactly your car your choice, our advice, dont have to take it, but dont have to get all shirty if you dont like our advice
  35. Davsurfa
    Davsurfa Member
    169
    Yeah ok
  36. 1animal1
    9,978
    hand bags at dawn eh........ this forum has been one of the best i have ever had the privilege of joining...... extremely informative with a multitude of personalities to boot.... excellent stuff :D
    Dav, you should be proud of what you've done - whether you keep it on or attempt to modify it further is up to you - hat off for trying - just don't forget that the forum, the people and information on it is absolutely invaluable - to ignore that fact will waste you half your life and potentially more money depending on what you plan next
    Tim
  37. Davsurfa
    Davsurfa Member
    169
    I bare it in mind. Next is grill removal but I've yet to figure out how.
  38. 1animal1
    9,978
    you'll need to remove the whole bumper IIRC.... do a search, tgheres plenty on it
  39. Paul @ Unit 9 Remaps
    2,035
    131
    nice, topic back on track
  40. Davsurfa
    Davsurfa Member
    169
    I'm sure I'll figure it, I only wanna remove the chrome trim not the whole grill. No worries.
