Shell VPower Nitro+
JudderMan Apr 18, 2013
  1. 16Klappe
    16Klappe I <3 Panda's! Supporter
    5,795
    1,183
    EGT's rise with lower octane ratings and the ecu richens up the charge to lower them back down again, which retards the timing further and restricts boost.
    Whether I had a bit of contamination in my tank, or these Nitro+ additives don't agree with my highly strung map I don't know. Time will tell.
    It hasn't ever done it even after repeated WOT pulls through all gears; I have taken it at WOT from 50mph to 155 in one go previously and it didn't back off once. And nor did it in the rolling road.
    JudderMan likes this.
  2. CHEZ
    CHEZ moderately amusing Supporter
    4,171
    839
    there is no way on earth that your a3 will hit 155mph! fact!
  3. rhubarb4
    rhubarb4 Certified Audi nutter Gold Supporter Team Silver Audi S3 quattro
    1,749
    186
    I agree chez absolutely no chance especially with all that buzz buzz buzzing going on in his head
    CHEZ likes this.
  4. 16Klappe
    5,795
    1,183
    Fcn Northeners.
    Where you been Chezza?
  5. CHEZ
    4,171
    839
    been buying me a speed camera, and i bet my left testicle on what i said above! :laugh:
  6. 16Klappe
    5,795
    1,183
    I'll bet you the log book on your dog walker-mobile :)
    155 is easy, a stage 1 A3 will get there given a long enough road mine does an indicated 160 with the higher limiter.
    It used to get to a point where you needed to take your foot off and on to push it up there. Not it just flys.
  7. s3dave
    s3dave TFSI Hybrid Supporter
    10,110
    736
    You wasnt dreaming of me towing you then jardo??...:laugh:
  8. 16Klappe
    5,795
    1,183
    Different dream Dave, you can tow me whenever you like.
    :beerchug:
  9. Paradox1
    Paradox1 Active Member
    1,833
    88
    I dont like you anymore
  10. CHEZ
    4,171
    839
    ah! a famous northern saying applies here!
    "YOU CANNOT SHOW A BIGGER COCK THAN THE ONE YOU HAVE GOT!" :sly:
    Brodster likes this.
  11. Brodster
    Brodster Well-Known Member Team Ibis VCDS Map User Audi S4 Audi Avant Owner Group
    3,548
    882
    You guys........you crack me up. An afternoon in the pub with you lot would be epic.
  12. Paradox1
    1,833
    88
    Dont worry Jardo, I believe you.
    Dont need a k04 to hit them speeds
  13. Kodak
    Kodak Member
    65
    Filled up with this awesome stuff in Sunderland on the A183 £1.40 p/ltr is the anyway to reset the knock sensor learned values to save me doing 100+miles before it works out ive uped the octane? Also I don't think its inpossbile for a k03 to hit 155 just need a huge runway and 245+bhp my brother did it on his mk4 golf 18t no mods just a good map but I think his is a k03s. Regards
  14. JudderMan
    JudderMan Well-Known Member
    1,004
    164
    I've sure I've noticed a difference in it. Pulls harder mid-range after a few tankfulls. Put some Esso 97 in on Monday as I couldn't quite reach the Shell garage and it's a bit flat compared and doing less mpg 33mpg compared to 38mpg when pootling around the same roads.
    Kodak, it's cheaper at Whitemare Pool (£1.37.9) only a few pence but every little helps. Can't answer your question about the knock sensor, though.
  15. the_cueball
    the_cueball Active Member
    494
    218
    43
    I've put a few tanks of Nitro in the S8 now.... and I do have to admit it does feel a bit smoother....
    Obviously it still does 297mph... ;)
    :thumb:
  16. Kodak
    Kodak Member
    65
    got to admit by the 2nd fill up it was pulling like a train much smoother even in low revs to be its total transformed the car throttle response is better, so from me its a hell yeah, i want the to try the 102 ron racing fuel will pay £2 per ltr + p+p :)
    gonna have a coffee before i hit the roads to do some data logging got to wait till after 1am really cos you hit xxx mph in 4th my last run said 262bhp but ive fixed the two leaks i found and it now shows -24 on the vac so hopefully thats it and on the boost it was showing 13psi ive reseated the charge pipe hose so hopefully it will be back to 21psi anyway here's hoping ...
