Shell V-Power vs Tesco 99RON
themanthatcan Jun 22, 2008
  1. themanthatcan
    themanthatcan Member VCDS Map User
    661
    Evening chaps,
    I normally fill up with Shell V-Power but upon visiting my local station this evening they had none in stock (petrol or diesel!) and they don't know when they'll have it back in again!
    What I want to know is if any of you have tried the Tesco 99 RON fuel in their S3? I've put a tenners worth of regular Shell Unleaded in for now and it seems to be running great but need to fill the tank up and am consideing trying the Tesco stuff and want peoples opinions.
    Ta,
    Andy
  2. phantom
    phantom On Boost
    1,750
    I only ever use Tesco99 , it will take a couple of tanks to work though.
    Better than V-Power IMHO
    p
  3. Bong Water
    Bong Water In two minds
    786
    There is a massive thread on this exact same subject from a couple of months ago
    For the record, Tesco99.
  4. phantom
    phantom On Boost
    1,750
    Cheaper and collect points to spend on your shopping......every little helps. LOL!
    p
  5. Nilz
    11,361
    899
    Hey thats strange, i was in Leicester yesterday and went to 2 different Shell petrol stations to get V Power and they didnt have any either!!!
    Is there a shortage of V Power???
    I ended up putting BP Ultimate in at £1.27 a litre!!!!!
    What is happening with the prices?!!???
  6. mad max
    mad max sixth gear
    338
    i read an article in evo magazine where they carried out a test on several cars using different fuel inc v-power or shell optimax as it was then called.conclusion was that bp high octane fuel and tesco 99 were as good if not better than optimax.now fill mine up with tesco 99 and myself with fosters when ive got enough points
  7. 1animal1
    9,978
    My nearest Tesco charge more for 99 than Vpower!!! grrr...Vpower now 122.9
  8. S3 Rav
    S3 Rav Well-Known Member
    2,825
    30
    i've had this dilema as v power is all out. i'v put in bp ultima and my car feels very sluggish with it compared with the v power. tescos i havent tried yet.
  9. Nilz
    11,361
    899
    Apparently V Power is out for about 3-4 days at least!!!
    I had to put shell normal unleaded in this morning...but seems ok.
  10. themanthatcan
    661
    Thanks for the responses chaps.
    After a drive to work this morning I really can't feel any difference using the normal Shell Unleaded, in fact it may be in my head but she seems to be slightly quicker :wtf:I always got the impression from others that there was a noticeable difference between Unleaded and V-Power but I'm failing to see it at the moment!
    Can anyone think of any reason why I shouldn't just stick with Shell Unleaded for now? I know the RON rating is slightly lower but I'm sure my owners manual says it should be ok, and I don't think the CC stage 1 remap allows for the extra power of V-Power anyway?
  11. 1animal1
    9,978
    errr might be worth checking as im sure CC increased a setting or two due to the vpower.... i say that as they were interested in what fuel i use and i assumed from their response that this made a difference
  12. jcs356
    jcs356 Brum brum
    2,734
    70
  13. TheSpaceCowboy
    TheSpaceCowboy Member
    520
    There was a test performed earlier in the year comparing Tesco 99 and V-Power in Independant Car magazine or something, V-Power came out on top in tests on a new Golf GTI.
    As far as I know the 2 fuels are different in the approach to getting to the octane rating, Tesco uses 5% Bio-ethanol to up the octane rating, Bio-ethanol produces less power than regular petrol though, so i'll stick to V-Power unless I find out bio-ethanol has a beneficial effect on engines designed for petrol.
    :blackrs4:
  14. smitch
    smitch Active Member
    1,588
    Can't say i've ever noticed any difference in any fuel i've ever used.
    All seems the same to me. :(
  15. AndyMac
    AndyMac Moderator Moderator
    9,832
    46
    You won't get any benefit from just one tank. You have to regularly use the same fuel in order to give the ECU time to work out how to use it.
    They did a similar test on TG or 5th gear (can't remember which) and Optimax (as it was then) came out as a clear winner on a rolling road BHP test.
  16. themanthatcan
    661
    I filled up with Tesco 99 RON this morning and it was the same price as V-Power (122.9). Will see how it goes.
  17. mad max
    mad max sixth gear
    338
  18. Kontraband
    Kontraband Active Member
    2,008
    yeah good stuff... and if you dont have time
  19. telaudi1
    telaudi1 New Member
    9
    tesco 99 al the way, i used to have a jap import skyline and it always run better and ther turbo spooled up slightly quciker when using tesco, v power is good but its not any better than tesco's
