shell helix ultra oil? G12?
campbell Feb 21, 2010
  1. campbell
    campbell Member
    721
    hi guys and girls,
    I have always used shell helix ultra 5w-30 oil in my 2002 audi s3 and i cant seam to find anywhere that sells it, can anybody point me in the right direction? My supplies doesnt supply it anymore!
    Also, what is the correct procedure to check the G12 coolant levels, should it protected to -20? I have checked it with the engine cold with a coolant gauge and its protected to 0 so i guess it needs more g12. Is it best to top up or completely drain the coolant and start again, if so how do you do it?
    Thanks in advance
    Campbell
  2. A3Tom
    A3Tom Smell my finger.
    3,504
    14
    You should be able to get the oil from the likes of GSF or Euro Car Parts etc :)
    As for the G12, you can get that as well so I'd get a bottle and do a complete flush if I were you. Looking at the very weak solution that came out of my engine when I changed my thermostat it was no where near enough in there. Now its a fairly dark pink colour...so for the sake of dropping a hose off I'd do the lot again. It tells you the dilution ratios on the bottles ;)
  3. campbell
    campbell Member
    721
    can you tell me which hose to take off to drain the tank?
  4. Matt82
    Matt82 Active Member
    2,365
    bottom rad hose would be a good start, ideally you want to get the stat out too to drain/flush the block.
    in the UK you want at least 30% antifreeze
  5. campbell
    campbell Member
    721
    can you get to this without ramps?
  6. Matt82
    2,365
    definately accessible from the top but it would be less fiddly if you were under the car.
    as for the stat, thats right on the front of the block so simple enough to do. pop a hose in there (and in the bottom hose) to flush all the old stuff out until it runs clear, then youre ready to go
  7. Welly
    Welly VX220 SC Driver :)
    10,696
    129
    There is a tap on the lower right hand side of the radiator on the S3 for coolant drainage and flushing. Well, thats what I always use it for anyway.....
