Sheffield - Anyone got vag-com ?
blackcat Oct 15, 2008
  1. blackcat
    blackcat New Member
    10
    My A3 1.8T Sport isn't working again :-(
    If anyone has vag-com and are prepared to travel to south Sheffield, please let me know, thanks.
  2. abdus
    abdus Top Gear VCDS Map User
    1,827
  3. 1animal1
    9,978
    blackcat i have VAG Com but only the free version...what functions do you need? just fault codes?...... in near crystal peaks
  4. blackcat
    blackcat New Member
    10
    Thanks 1animal1, my car will start up, rev up once and then die. I have spoken to the mechanic who doesn't know what the problem could be, I have another post on here regarding what's wrong.
    I just wanted to try and find out what it could be so that I could tell the mechanic and he can fix it, would the free version of vag-com tell me this ?
    Sorry to be very vague but I don't know the first thing about cars !
  5. 1animal1
    9,978
    if its a fault code then yes, otherwise your best bet is to take it to JBS at Whittington Moor near James Cycles at end of Dronny Bypass..... they charge around £50 an hour to diagnose....might save you a lot if youve started replacing parts....ill happily wack it on vag com freeware to do a preliminary check though if needs be
  6. JBS Sales
    JBS Sales Member
    395
    How did you get on with this?
    Sounds like it could be an immobiliser fault:
    As animal said we can check the car over and double check the faults for you.
    Kind Regards
    Mike
  7. benr
    benr Member
    819
    Yeah sounds like the immo to me too - possibly the part which reaads the transponder from the key. But if it was this the immo light should flash.
  8. S3 Paul
    S3 Paul Well-Known Member Regional Rep
    2,825
    107
    Hi there,
    I live in Rotherham and have vag com...
    PM me if you need to check the car for faults,
    Paul
  9. 1animal1
    9,978
    Paul didnt realise that you were Rotherham fella...... impressive spec list:beerchug:
  10. S3 Paul
    2,825
    107
    Thanks mate.
    Ive never seen a dolphin grey S3 localy !
    The spec will maybe change in the new year but im not sure...
    Let me know if you get stuck for VAG COM
