Sharpening the steering on a MK2 TTS
calumski Feb 14, 2009
  1. calumski
    calumski New Member
    This is my first posting on here so my apologies if this is already a well-worn topic.
    As it rolls off the forecourt, the MK2 TTS steering is set too conservatively for my liking. Has a generally-accepted solution to this lack of erm.. alacrity .. been developed yet?
    Calum [​IMG]
  2. dunk
    dunk Member
    770
    the tt and golf v and a3 8p seem to use the same parts generally and have the same handling foibles, notably understeer and a central vagueness/numbness
    if you want to sharpen the steering response and get rid of some of the centre vagueness at the expense of making the car feel a little less stable at high speed, then you need to:
    1) increase front negative camber with either modified lower wishbones or adjustable top camber plates
    2) increase front castor if you can - only with adjustable top camber plates
    3) reduce the rear negative camber a little (factory adjustable thank goodness)
    4) reduce the rear toe to neutral but dont go toe-out or you will get danagerous road handling
    5) uprate anti-roll bars front and rear
    if i had an s3 or tts then i would go for a set of morego bottom suspension arms (negative camber but factory bushes/noise/ride) and a good set of ARBs, probably neuspeed, and reduce the rear toe in to neutral - wouldnt do anything else
  3. calumski
    calumski New Member
    Dunk,
    spot on info. I didn't realise that BBR produced bottom arms. There's a good chance they provide a drive-in, drive-out solution, using their Morego parts.
    I'll get in touch with them and see what they say.
    Calum :beerchug:
  4. dunk
    dunk Member
    770
    the morego solution is £500 fitted, but if your old arms are cast rather than pressed steel then there is another £120 or so as your old ones are no use to them to be modified
  5. Tankman
    Tankman Member
    54
    Can I suggest you try a specialist chassis tuning. I recommended a friend to visit Center Gravity
    http://www.centergravity.co.uk/
    Having driven his S6 Avant, I thought it was probably the vaguest most uncommunicative car I had ever driven. He had his car sorted for £250+VAT and his testimonial is on their site.
    Center Gravity have turned my old smoker into a fantastically responsive car even with that great big heavy lump sat over the front wheels.
