Shall I change my MAF?
themanthatcan Jul 28, 2008
  1. themanthatcan
    themanthatcan Member VCDS Map User
    661
    In the ongoing saga to sort my car, I tried unplugging my MAF the other day before driving to work. To my surprise the car didn't appear to run any differently; it initially coughed a bit from cold but after a few seconds it seemed ok.
    What does this tell me about the MAF; Good or bad? I was expecting the car to really struggle! :shrug:
  2. abdus
    abdus Top Gear VCDS Map User
    1,827
    Why not try vag-com and check for any fault codes?
  3. themanthatcan
    661
    Been there done that matey. It's had all systems checked at JKM and given the all clear, but something must be up with it otherwise it wouldn't only be running 207BHP.
    I've now got to the stage where I feel I need to try swapping a few key parts in the hope that it fixes the problem.
  4. 1animal1
    9,978
    dont you have to run a 'set up' from vag com when changing the MAF? im hopefully gonna have a new 1 by the weekend.....
  5. h100vw
    h100vw Member
    218
    I don't think so, just stick it on and drive. I didn't do anything when I changed one on an A4 1.8T years ago.
    MAF faults don't usually show up as codes for some reason. There wasn't one on the A4 it just didn't go any better after it was chipped.
    Gavin
  6. Lee_shep
    Lee_shep Member
    52
    My car is hesitating slightliy on boost so I unplugged the MAF and it's boosting like it should do. Was a bit worried that it may be something else. I shopped around for a new one and spoke to VAG parts in Swindon who always seem to be cheap and supply genuine Audi parts, they told me the cheapest thing to do is take it to Audi who will exchange it for a new one and charge £64.00 + VAT which isnt bad. Before I do that I'm going to try and clean the sensor with some contact cleaner, anyone tried this?
  7. Essflee
    Essflee Well-Known Member
    2,142
    66
    [/quote]What does this tell me about the MAF; Good or bad? I was expecting the car to really struggle! :shrug:[/quote]
    I thought if you disconnect the maf and the car still runs the same then you do indeed have a maf issue....got to be worth ago !!
    Process of elimination......:unsure:
  8. abdus
    1,827
    Just ordered mine today. new maf= £64+ old one
    will post back when changed
  9. HTC
    HTC Active Member
    3,428
    9
    Gav, later cars sometimes need the ECU reset and codes cleared to recognise the new MAF. This is how it was with Clare's Golf when she had it.
  10. h100vw
    h100vw Member
    218
    Kev, was going on personal experience with an APU engined A4. There were no codes in the ECU on it. Would you needed the reset if there were no codes do you think?
    Gavin
  11. HTC
    HTC Active Member
    3,428
    9
    I would say that if there were no codes and the CEL wasn't on, then a straight swap should work.
  12. 1animal1
    9,978
    i have just changed mine on my BAM engine...... and guess what....... cant feel any difference :keule::lmfao:
