SEVERE 'WOBBLE' ON Audi A3 T FSI SPORT QUATTRO 5 DOOR HATCHBACK (2005)
owlfandan67 Jun 4, 2013
  1. owlfandan67
    owlfandan67 New Member
    Afternoon,
    I have an Audi A3 Quattro sportback 2.0l turbo and it has developed a ‘wobble’ which I believe is coming from the back end, the best way of describing it is that it feels like there is a gust of wind blowing the car every so often. I have had it looked at in the recent past and it looks as though there may be something wrong with the 4 wheel drive system as the mechanic says he thinks one of the wheels is moving independently from the others? he also tried to re track the car after two front wheel bearing and he says he couldnt get it close as the back end was out from the front ? 8 or 12mm difference i think he said?
    Couple of questions im hoping someone may be able to help me with is :
    1. Has anyone heard of this before ? and what should i be looking at fixing ?
    2. Is it dangerous ? it seems pretty stable and the mechanic hasnt told me to stop driving it ...
    3. if it is the transfer box bearing as he says is a pure guess how much am i looking at forking out? as im in the middle of buying a house so funds are low at moment.
    Audi are quoting £113 for the diagnostics is there any cheaper options out there that people know and trust in the sheffield area?
    thanks for any replies in advance
  2. NHN
    29,300
    1,702
    The unfortunate thing is, its a physical check mostly afaik, so no matter where you go its going to take time to diagnose, may require stripping down some parts to properly diagnose, so find a very good vag indy to minimise your hourly rates.
  3. wuta3
    wuta3 Well-Known Member
    1,124
    347
    Id say any car you are describing as having SEVERE WOBBLE ... probably don't drive it lol ... that's my non-expert opinion.
  4. boost-addict
    boost-addict Well-Known Member
    1,000
    39
    id say the bushes on the wish bone. or at least a bushing of sorts.
    i know its not the same but my bros car passed its mot few months back and then one day few weeks back he went to drive off but i called him and he stopped and i noticed the wheel was moving forward under braking pressure.
    turnt out the rear bush of the front lower arm was cracked, but we got a pry bar and it didnt budge but you could actually see it moving applying and reapplying the brakes at a slow walking speed
    so id say its gotta be some thing along those line, but as nhn says take it to a dub specialist as they will know were to start and what bits to look at. thing is even with the longest pry bar you cant exert the force applied by the cars lateral forces.
  5. Artimus
    Artimus Shortback
    2,012
    482
    from your description it sounds like the driveshaft spline might be exiting the rear box or similar ...now I know jack about quattro systems, but I wouldn't drive it as you risk causing serious damage & a having big accident if that's what's happening.
  6. boost-addict
    1,000
    39
    As far as im awar the dive shaft spline can not pull fromt he diff. The drive shaft is bolted to the output drives. . Als
  7. boost-addict
    1,000
    39
    Firstly there would be way more then a wobble to pull a driveshaft. Plus the drift shafts are bolted to the out put shafts on the diff.
    So as you said you have no idea about quattros so you cant make second gueses. Its only going to be bushes as things like wheel bearings and visual damage would have been quickly spotted.
  8. Artimus
    Artimus Shortback
    2,012
    482
    be interesting to find out, don't you think? :)
  9. boost-addict
    1,000
    39
    yer would be.
    i was going to say it could be a deformed, faulty tyre but it happens occasonally
  10. Brodster
    Brodster Well-Known Member Team Ibis VCDS Map User Audi S4 Audi Avant Owner Group
    3,548
    882
    My old S3 kind of done the same thing but had a droning/vibration along with it. Turned out that the top hat section of the propshaft where it went into the diff had started to shear so was replaced under warranty. This happened twice on the same car so I dont know if it was a batch of dodgy propshafts.
  11. Turbo jay
    Turbo jay Leather repair specialist
    577
    69
    As already said it does sound like bushes, check the arb bushes also for wear.
  12. phil76
    phil76 Active Member
    572
    40
    I would have also thought propshaft bushes by the description but that wouldnt really through the wheel alignment out
  13. owlfandan67
    Cheers ill have a look in to your ideas and hopefully keep you posted on what i find, maybe severe is a bad choice of words but it is annoying and worse when there is passenger in the back !
  14. phil76
    572
    40
    Where are you at then someone might be able to point you in the right direction of a good independant specialist in that area?
  15. owlfandan67
    i am in sheffield mate
  16. phil76
    572
    40
    So am mate ,will send you a pm now
  17. Garfybeds
    Garfybeds Active Member Audi A5
    166
    26
    Sorry to resurrect an old post but what was the outcome of this ? I am having a wobbling under acceleration issue with my 2.0 FSi tiptronic
  18. owlfandan67
    It was the rear suspension arm bush that had failed .... 3 out of 4 garages didn't spot it which I wasn't very happy about bit it's fixed now
  19. Garfybeds
    166
    26
    I have mine booked in to Audi Milton Keynes to diagnose the problem - I'm really hoping they can identify the problem.
